06-26-2008, 11:38 PM | #15 |
Camaro Deprived
Drives: 78 Camaro, 00 Tahoe, 10 Cobalt Join Date: May 2008
Had this same problem in my Tahoe. It "IS" condensation. The seal around the headlight goes bad, and water is allowed in. or theres a small hole in the seal or casing.
Edit: ok i just got done reading everyone elses posts here, and the only way to know for sure is if you were able to look at one closely to see if its water or not.
My posts are of my opinion most of the time.
I am young and inexperienced. Please don't hate on me for it. Joined Active Navy: 10-28-08 |
06-26-2008, 11:54 PM | #16 |
Iroc-Z <3'r
Drives: '87 5.7L Iroc-Z Join Date: May 2008
Those are pretty sweet lookin, '77, bet those cost a butt load tho
"Camaro Z/28 is back. Gentlemen, Don't even bother to start your engines." |
06-27-2008, 12:07 AM | #17 |
AutoBot Scout
About $250 for the pair
06-27-2008, 12:18 AM | #18 |
Iroc-Z <3'r
wow thats cheap, i love those new eyeball-like headlights they have now a days, they're great light.
I was driving a Lexus ES 330, those have those eyeball lights..they're pretty bright..and when I turned the brights on it was like looking into the sun (not really but Damn they were bright - the extra lights that is, not the eyeball ones) but the eyeball ones contributed to the brightness of course, driving out in the country to work - that sorta thing comes in handy when theres ZERO light whatsoever (at night), in comparison to my taurus' standard lights. (Post #100 woohoo, lol)
06-27-2008, 12:22 AM | #19 | |
Iroc-Z <3'r
06-27-2008, 07:52 AM | #20 |
Keeper of the Faith
Drives: 2001 Z28 Agressively Join Date: Apr 2008
There are two possibilities. If you have glass sealed beams, its most likely condensation and you have a crack or hole in the glass. If you have plastic headlight housings with replaceable bulbs, its most likely not condensation but fogging of the plastic. You could also have condensation on the plastic housings if you have leaking seals around the bulb or a hole/crack in the housing somewhere. In either case, if you have a hole/crack you will have to replace parts. If its just the fogging of the plastic, then you can just repolish.
The OP referred to the 4th gen f-bodies, so in that case 90% of the time its just fogged plastic not condensation.
2010 Camaro SS R6P 2001 Camaro Z28 1969 Camaro SS clone |
06-27-2008, 02:01 PM | #21 |
Iroc-Z <3'r
that makes sense.
ty again to repliers, rather unfortunate that they still use plastic covers =/
06-27-2008, 05:12 PM | #22 |
Drives: 2000 Camaro Join Date: Jul 2007
Autozone normally has stuff that's called Blue Magic Headlight Lens Restorer it's $5.99 for a 8 oz bottle.
06-27-2008, 08:26 PM | #23 |
Iroc-Z <3'r
Hmm I'll have to look into that...
definitely not a bad price at all tho if it works effectively.
06-28-2008, 07:24 AM | #24 |
Keeper of the Faith
I just picked up a bottle of Mequires Plastic cleaner/polish yesterday and it worked pretty good. I only had enough time to do one side though. Its was about $7 a bottle. I have a lot of chips in mine. Looks like I'll have to do something more aggressive like sanding. I might try spraying them with automotive clear coat and then sand them down.That will fill in most of the chips, and I could add a touch of blue to give them a slight blue tint.....hmmmm
06-30-2008, 05:06 AM | #25 |
Iroc-Z <3'r
yeah your car is a perfect example of what I was referring to, txturbo:
06-30-2008, 05:14 AM | #26 | |
Iroc-Z <3'r
and as for you TAG, !!
"Or, just use 'Plast X' from Meguires. Clears it right up." ...in your defense, we hadn't identified it yet as being fogged up plastic, but rather the supposed condensation. but!.. you still shoulda known! ( j/k just giving you a hard time )
06-30-2008, 05:17 AM | #27 |
Iroc-Z <3'r
hey '77, post some pics up if/when you get those other headlights installed, when you get the chance, I'd love to see em
06-30-2008, 01:53 PM | #28 |
AutoBot Scout
sure thing, might be awhile im doing my exhaust soon but ill post a vid of the sound of my new agressive V6 rawr!!
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Post up your 4th Gen. Camaro | 09'Z28 | 4th Generation Camaros | 1365 | 02-07-2024 10:26 AM |
4th Gen Miles Question | dobbins67326 | 4th Generation Camaros | 13 | 09-05-2008 10:37 AM |
Flying 4th Gen... | bprange | 4th Generation Camaros | 4 | 05-30-2008 02:00 PM |
4th Gen General Questions | selil | 4th Generation Camaros | 8 | 04-04-2008 07:30 PM |
Anybody with an Auto 4th gen? | Mr. Wyndham | Off-topic Discussions | 14 | 09-16-2007 12:46 PM |
