12-04-2023, 07:26 PM | #1 |
Black lightning
Zl1 1le E50 tune
So I got a retune today, I was on E37 prior and bumped it up to E47 with CAI, Lt header same mods ONLY. ITS in the 50s I’m thinking I’d be okay #s however I drove an hour and a half to get there with a little happy foot here and there then I had to add more E with more happy feet to get the gauge to display proper E%. Finally got to the shop and went basically to doing pulls. So at 6 psi of heat soak boost left l ended up with 628 wheel. I was 637 on E37!!
Same shop during the Warmer months and a different shop location. (Not far but still) the dyno far as I know want SAE so don’t ask lol. The dyno Shown is the one prior to 628 the last pull. Looking at the forum it’s right on point. I suppose a re dyno on 8 or 9 psi would yield around 649. However, even with the heat soak I can still a significant jump from the timing adjustment l/fuel
[ 2021 Camaro ZLE 10 speed
12-05-2023, 05:23 PM | #2 |
Drives: 2018 CAMARO ZL1 Join Date: Mar 2023
What gear was it dynod in?
12-05-2023, 07:25 PM | #3 |
Black lightning
12-05-2023, 07:35 PM | #4 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Why tune for a specific Ethanol percentage? Are you not using the FlexFuel sensor?
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
12-05-2023, 08:17 PM | #5 |
Black lightning
You have to use a sensor to use Ethanol gas. And you have to tune to a certain percentage so you won’t run lean or mainly destroy your high or low side fuel pump, I have a gauge Inside the car which tells me the percentage. So E50 is kind of like safe zone DEPENDING on how many mods you have. The more mods generally means the less ethanol you can use
12-05-2023, 08:18 PM | #6 |
Black lightning
12-05-2023, 09:23 PM | #7 | |
The stock LT4 fuel system doesn't allow the use of E85, it simply can't pump that much fuel that quickly, but diminishing returns kick in past E60-E65 anyway. If he only ever puts E50 or lower in, technically the tune doesn't need to be spot on past that point (thus "tuned to E50"), although I would ask my tuner not to do that and scale the tables properly through to E85 anyway.
12-06-2023, 09:58 AM | #8 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
I was sorta confused at what OP is trying to say. The grammar was difficult to interpret. I thought he was trying to say E37 vs E50 gains are shown on the graph but I could be wrong.
12-06-2023, 12:47 PM | #9 | |
Black lightning
