Old 03-17-2021, 06:33 PM   #1
R2R martini
Drives: SS 1le coming
tow hook install HELP!!!
the owners manual is useless. On a 2021 SS 1LE front grill, I can see the cut out on the grill but there are no clips to remove the piece to access the tow hook. there are no videos either. Has anyone done it?
thanks in advance.
R2R martini is offline   Reply With Quote
Old 03-17-2021, 06:53 PM   #2
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Yeah I was looking at mine and the hook won’t fit through the grill . No cut out on mine nor does a section pop out. Looks like you have to cut a grill fin out to make it work?
VR Baron is offline   Reply With Quote
Old 03-17-2021, 07:02 PM   #3
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Section pulls out....grab and pull..
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 03-17-2021, 07:08 PM   #4
VR Baron
VR Baron's Avatar
Thanks, I tried but didn’t budge. More elbow grease required..lol
Old 03-17-2021, 07:11 PM   #5
nprario
nprario's Avatar
Drives: 2017 1ss 1le HBM
There should be a small slot type area you can insert a flat head and pry down to pop it out. At least that works on my 2017. I did not pull by hand that hard because I thought I would break it. When I found the spot it popped right out with the flat head.
nprario is offline   Reply With Quote
Old 03-17-2021, 08:30 PM   #6
VR Baron
VR Baron's Avatar
Found it. You wouldn’t even know it was there. Now for a decent looking tow hook. The one Chevy gives you belongs on a battleship
Old 03-18-2021, 05:44 AM   #7
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
well our cars do weight around 4,000lbs... so pretty much a battleship
That1guy_tim is offline   Reply With Quote
Old 03-18-2021, 10:30 AM   #8
VR Baron
VR Baron's Avatar
Old 03-18-2021, 12:00 PM   #9
pbsinternet1le
3680lbs
2017 1LE Hyper Blue
Old 03-18-2021, 01:53 PM   #10
VR Baron
VR Baron's Avatar
3680lbs
3802 here. By the sticker
Old 03-18-2021, 02:07 PM   #11
davidwarren
Drives: 2019 SS 1LE
I used a plastic trim tool to pry the cover out. I cut it a bit so that I could leave a tow hook in all the time since this is a track toy.
davidwarren is offline   Reply With Quote
Old 03-22-2021, 07:21 PM   #12
Racer713
Drives: 2020 Camaro 1SS 1LE
It was a little tricky to remove. Hopefully, this pic helps. I used a Dremel with a sanding drum to make room for the tow hook.
Racer713 is offline   Reply With Quote
Old 03-22-2021, 10:20 PM   #13
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
#3702 here as of this weekend.
The ZL1addons tow hook is nice. https://zl1addons.com/collections/camaro-tow-hooks
I have the GT4 hook on mine.
It has a shaft that goes into the OEM location. The hook goes on/off with a 10mm hex. So you can leave the grille cover on when the hook is off.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 03-23-2021, 07:58 AM   #14
ste6000
ste6000's Avatar
Drives: 2018 Camaro SS
4002 when holding the stick in the car. ><
2018 Camaro SS - Hyper Metallic Blue
ste6000 is offline   Reply With Quote
