05-18-2021, 11:48 AM | #85 |
Since this is all about removing heat, I may put some heat shield tape on mine between the valve cover and the side/bottom of the reservoir, and on the bottom of the reservoir
'20 ZL1 1LE A10,
05-26-2021, 02:10 PM | #86 |
Given that it's on the valve cover and a few inches from 300F headers, I had the idea that the reservoir fluid would be cooler if we insulated it. See pic. However, initial indications are that is not the case as temps now read a bit higher. We'll see.
'20 ZL1 1LE A10,
05-26-2021, 02:53 PM | #87 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Ceramic coating the headers should help considerably. Under hood temps are dramatically lower than with oem manifolds or with uncoated headers.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
06-12-2021, 09:18 AM | #88 |
Drives: 2022 ZL1(FEA suspension) Rapid Blue Join Date: Apr 2019
FYI to Canuck ZL1 owners. Just received my V2 FROM ADM. By the time it got here including shipping and custom fees it was just over $430CAD. Brutal, but worth it I think. Especially if you track her.
06-12-2021, 10:50 AM | #89 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
06-14-2021, 02:04 PM | #90 |
Drives: 2020 ZLE A10, 2018 F250 Diesel Join Date: Apr 2020
Thanks for all the info. Ordered one today. Too bad I didn’t get in on the group buy.
07-04-2021, 04:59 PM | #91 |
Completed the install last night. Really easy and straightforward. I too swapped out the back fitting to keep the OEM service port and also trimmed the hoses for a better fit. Filled with coolant and bled over 10/15 minutes.
So.... Drove it for the 1st time today. I gotta say that it really seems to pull harder now. Not sure if it's the plaseabo effect, but the torque under boost feels WAY stronger. Maybe not pulling timing? I have no real way to quantify. It feels as though I have another 70 or 80 ft/lbs. Maybe just me, or I did actually have air in the system. Considering most of my miles are done on the track, I call this cheap karma knowing I'm getting all my ponies when requested. |
07-05-2021, 09:22 AM | #92 | |
07-05-2021, 10:53 AM | #93 | |
'20 ZL1 1LE A10,
07-05-2021, 12:44 PM | #94 |
Drives: 2019 ZL1 Join Date: Mar 2019
Get yourself an ibanks or similar gauge pod so you can see exactly what your car is doing. Monitor IAT, MAT, TIMING, BOOST etc.
This is how I have mine setup.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
07-05-2021, 01:17 PM | #95 |
could you review on your lower Banks gauge with the IATs and MAT variants...explain what you know about where/if they are sensor readings or if any of those readings are calculated.
07-05-2021, 03:59 PM | #96 | |
MAT temps are the most important. This is reading actual temps inside the blower. In my case, I am not using the breakout which relocates the sensor to the front of the 2650, I’m Using the sensor in the rear which is the combination TMAP sensor. CSP does this instead of using the breakout cable as they say gives a more accurate readout. This isn’t calculated, it’s actual temps. IAT2 is calculated and there’s various debate whether it’s a calculated value from ECT/IAT 1 etc. either way it doesn’t make a difference as nothing uses that in the ecu as far as timing advance or retard. Depending on conditions it’s usually within 10 degrees of IAT1.
07-22-2021, 02:09 PM | #97 |
Shadow Gray '19 ZLE M6
Installed on my ZLE today. As everyone has mentioned, it's super easy. Only takes a few minutes.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
07-22-2021, 03:01 PM | #98 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
Well, I waited this long. I may wait and see if there is a sale on them again in the near future.
