07-03-2022, 06:55 PM | #29 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Why not just put the OEM wheels/tires back on your car? Chalk it up to a learning lesson. Expensive sure, but it is what it is.
07-03-2022, 08:49 PM | #30 | ||
Drives: 2022 2SS Join Date: Feb 2022
Offsets are correct yes |
07-05-2022, 08:11 AM | #31 | |
Drives: 2021 LT1 6spd Join Date: Nov 2020
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
07-05-2022, 12:07 PM | #32 |
Drives: '22 LT1 Coupe Join Date: Nov 2021
Was looking at some Chevy OEM wheel specs for my '22 Camaro, and they weigh between 26-28 lbs. OP's replacement wheels are 43% to 53% heavier than my OEM.
Looked at a few lower-priced replacement wheels on Discount Tire site and they are 33-34 lbs. OEM for me. . |
07-05-2022, 03:19 PM | #33 | |
Here’s my setup, which have the wheels being very close to the factory LT1 wheel. I weighed these using the bathroom scale. Ace Alloy AFF05 20x 10 25 lbs Ace Alloy AFF05 20x 11 26 lbs Michelin PS4S 285/30 27 lbs Michelin PS4S 305/30 30 lbs
07-05-2022, 04:20 PM | #34 |
Drives: Rapid Blue 2022 Camaro 1SS Join Date: Sep 2021
yes, but ET's for the front/rear wheels are different.
9/9/2021 - 1100 (date of deposit)
10/15/2021 - 2000 11/4/2021 - 3100 Status TPW 11/15 11/9/2021 - 3400 Status TPW 11/15 11/24/2021 - 3800 Status built 11/21/2021 12/2/2021 - 5000 Status 12/13/2021 - 6000 Status |
07-20-2022, 05:12 PM | #35 |
Ok guys .. going for the Apex SM-10 wheels 19 inchers.. tires are on the way and are Michelin Pilot sport 4s .. thanks for all the feedback and pointers
07-20-2022, 05:31 PM | #36 |
PaPa Smurf
Also with the 305 in the rear of a non ZL1 or SS 1LE, has the factory started moving that harness that everyone rubs raw and causes the CEL? Been out of the game a couple years, so also look into if you need to relocate that harness before you rub through it with the wider setup.
2022 Rapid Blue SS 1LE
07-20-2022, 07:01 PM | #37 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
305/35R20 will rub 315+ will rub
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
07-30-2022, 02:17 AM | #38 |
Drives: Chevrolet Chevy Join Date: May 2022
Damn this is a nice update. Your set up won't get much better than that for street driving. Sick! Post pics when it's on the car
