Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 06-08-2019, 11:01 AM   #1
My First Camaro!
My First Camaro!'s Avatar
Drives: '18 5.7 RAM 1500 18' 1SS
345....?
cRaZy question:
What would it take to fit a 345 in a SS 1LE ZL1 ZLE?
JRE Tune
My First Camaro! is offline   Reply With Quote
Old 06-08-2019, 01:39 PM   #2
Larrio Andretti
Drives: Really Fast
Fender flares!
THIS SPACE FOR RENT
Larrio Andretti is offline   Reply With Quote
Old 06-08-2019, 07:32 PM   #3
UrbanKnight
Drives: Fastish
Done it with 18's
https://www.camaro6.com/forums/showthread.php?t=549850
UrbanKnight is offline   Reply With Quote
Old 06-09-2019, 05:56 PM   #4
My First Camaro!
Originally Posted by UrbanKnight View Post
I see! That's amazing..... I wonder how it would fit on 19" ZLE wheels? Any idea how the ZLE struts/spacing compares to a non-mag SS?
JRE Tune
Old 06-11-2019, 09:33 PM   #5
Markoz28
Drives: 18 ZL1 nightfall grey A10
Go by what size wheel and off set you have now and with what size tire? Jack the car and look under it and see what components are closest to the wheel/tire and try and measure the distance between them. This will give you a starting point as to how wide you can go.
Markoz28 is offline   Reply With Quote
Old 06-12-2019, 03:14 PM   #6
Torquem
Bannable
Torquem's Avatar
Drives: 2017 Camaro ZL1
I have been told by a couple custom wheel manufacturers that a 345 on a 12.5" rim will fit.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic
Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's
Torquem is offline   Reply With Quote
Old 06-12-2019, 04:51 PM   #7
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Nothing, I am planning on running the 355/30R19 ACR Kumho's on the rear of mine on stock wheels with no mods.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/channel/UCBV...6JL3aD81mLGh8w
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 06-12-2019, 05:34 PM   #8
Move_Over
Drives: ISO ss 1le
ZLE DSSV struts and spring perch are way way smaller. 18" will not fit unless you grind your strut and and use a spacer. (or have crazy low offsets - like, 0.)
Move_Over is offline   Reply With Quote
Old 04-16-2020, 12:11 PM   #9
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I haven't had an issue with 345 30 19s on zl1 1le replicas 19x11 38mm offsets. I picked up factory rears 19x12 41mm offset is this going to make the tire closer to the harness in drivers side rear fender liner?
Old 04-16-2020, 12:49 PM   #10
MRLZL1LE
MRLZL1LE's Avatar
Drives: 2018 Chevrolet Camaro ZL1 1LE 6MT
How did these fit? good grip? Im at 750/750 RW and need more traction!
2018 ZL1-1LE
Rotofab, Ported TB, 2.3 Pulley, ATI balancer w DSX 9.06 Lower ring, LME heads, 2" Kooks, custom cam, DOD Delete, Cordes Low side fuel system, Flex Fuel Kit, MM Catch can, ZL1 addons tow hook, ZL1 addons rock gaurds, Diode dynamics blacked out side markers
MRLZL1LE is offline   Reply With Quote
Old 04-16-2020, 02:31 PM   #11
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Just fine the Tire over hung the rim a little but the grip is awesome
Old 04-16-2020, 02:35 PM   #12
MRLZL1LE
MRLZL1LE's Avatar
Any pictures of the overhang?
2018 ZL1-1LE
Old 04-16-2020, 02:54 PM   #13
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Here's a 325 vs 345
Old 04-16-2020, 03:14 PM   #14
MRLZL1LE
MRLZL1LE's Avatar
Here's a 325 vs 345
Awesome! are these 355 or 345? also are these the 888Rs?
2018 ZL1-1LE
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
