01-22-2020, 01:22 PM | #1 |
Drives: 2010 Camaro SS Join Date: Nov 2019
Gauge pack readings. What is bad?
Just curious I have been keeping an eye on my gauges to check my car health but it occurred to me I really dont know when im in trouble.
When is it time to worry, short of 0 oil pressure and immediately stopping the car? Edit: Sorry forgot to mention this pic was idling in a drive thru after driving all day. Oil pressure is at 30 normally when I'm moving. I was curious, for example on a cold start. You should make sure you reach a certain temperature before going WOT etc etc. Sent from my SM-N950U using Tapatalk Last edited by Chomorro; 01-22-2020 at 01:58 PM. |
01-22-2020, 01:50 PM | #2 |
Drives: 2018 GT350 Join Date: Nov 2011
Everything except your oil pressure looks normal. That oil pressure looks low. How many miles are on the car?
Off to the Dark Side
01-22-2020, 01:51 PM | #3 |
Drives: 2010 Black 2ss Camaro SS Join Date: May 2010
I wouldn't overly rely on those gauges, they are not very accurate. but those readings are fine. Trans should be under 190ish, volts around 14.5, oil pressure and oils temps are good.
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
01-22-2020, 01:51 PM | #4 |
Is your car at idle there? That oil pressure looks awfully low for what I am used to, but every car is different of course. How many miles on your car?
Even before my Melling HV pump, my stock pump was always above 30 psi idle in the L99. With my new pump on the LS3, I idle at 42 psi and max around 65 psi, checked via an independent gauge. Please don't freak out. I just noticed your oil pressure is lower than I am used to.
01-22-2020, 01:52 PM | #5 |
Started#gottalovethatblue
Looks pretty normal for a warmed up car.
01-22-2020, 01:58 PM | #6 |
I was curious, for example on a cold start. You should make sure you reach a certain temperature before going WOT etc etc. Sent from my SM-N950U using Tapatalk |
01-22-2020, 02:01 PM | #7 | |
I am sure others do it differently, that is just my preference.
01-22-2020, 05:54 PM | #8 |
If you really wanted to verify oil pressure, add a quart of 5W40 oil. I run my V6
on Castrol or M1 5W40. With that lil'bit of fresh, thicker oil, it should raise the gauge. Or, do it just before your next oil change if the thought bothers you, having 5W40 in there. Let it get it hot, check the gauge, add the 5W40, then check again. |
01-22-2020, 05:57 PM | #9 |
Drives: 2015 Black rs/ss/1le Join Date: Apr 2018
All pointers should be, more or less, pointing straight up, then you’re good to go. My volts are typically to the right of center, just like yours. Oil pressure sounds like how my oil pressure behaves.
Now, if only we can see the gauges and instead of the radio knob. |
01-22-2020, 08:13 PM | #10 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Man I wish my trans temp was like that. Mine looks like that, but faces the other way. Nothing feels wrong with the trans, and I've done a flush and filter change already.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
01-22-2020, 08:30 PM | #11 | |
01-23-2020, 06:37 AM | #12 |
OP, your numbers look like a car that is warmed up. Nothing abnormal. When you're driving you might notice the oil pressure go up because the rpms are higher, but it is normal. Mine ran like that for years until I got cammed and they modified my oil pump to pull more pressure.
01-23-2020, 08:07 AM | #13 |
Drives: 2012 2SS INFERNO ORANGE Join Date: Apr 2015
oil pressure is lower than my 2012 12k miles ss..mine sits around the middle on idle
01-23-2020, 10:30 AM | #14 |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
If there is ever a problem you will have a warning on the dash display. BTW my gauge pack reads just a little lower than yours warm and at idle. Only around 30psi when cold and that's with a brand new motor, oil pump and O-Ring. Stock Oil Psi gauge is Not the most accurate gauge in the car.
GJDM |
