Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 12-14-2019, 11:14 PM   #1
Chomorro
Drives: 2010 Camaro SS
Z28 replica 20x10 +35 square fit 2010 SS?
I saw some replicas that are 20x10 +35 with 285/30 tires all around. Pretty good price but I cant find the answer if they will fit a factory 2010 as non lowered without rubbing.
Would hate to have to get different tires since these have good tires.
Thanks!
Sent from my SM-N950U using Tapatalk
Chomorro is offline   Reply With Quote
Old 12-15-2019, 12:10 AM   #2
SSammy
SSammy's Avatar
Drives: 2015 2SS A6 Commemorative Edition
Thanks!
Pretty sure they’ll fit just like mine do on my 2015. 285/35zr20 was the recommended size for the fronts when I bought my wheels. I have 20x10 +35 MRR M228’s with 275/40zr20 (taller than a 285/35zr20 and comes closer the the spring plate on the front struts) DWS06’s at all 4 corners. No rubbing, no spacers needed and eliminated nearly all of the inherent understeer. About 5/16” clear between strut and sidewall on the fronts and rears have ample room everywhere. Hope this helps.
SSammy is offline   Reply With Quote
Old 12-15-2019, 12:22 AM   #3
SSammy
SSammy's Avatar
Just noticed you said 285/30. Those should have even more clearance, but are smaller diameter, so your speedometer will be off by about 7%. With the 285/30r20 if your speedometer shows 65, you’ll actually be doing about 60
Old 12-15-2019, 12:30 AM   #4
Chomorro
That's exactly what I was looking for thanks! So for the speedo to be correct I would need 285 35 tires all around?
Old 12-15-2019, 01:54 AM   #5
SSammy
SSammy's Avatar
275/40zr20 and 245/45zr20 are what the Camaro SS came with and are 28.66” diameter. 285/35zr20 are 27.86” dia and would put you around 63 mph when the speedometer reads 65, and 285/30zr20 are 26.74” dia and puts you around 60 when the speedo reads 65. Nothing wrong with running any of these sizes, but you have to keep the speedo difference in mind. I went with 275/40zr20 to keep the speedo reading correct, but the lower profile sidewall of the 35 and 30 series tires do have their own advantages when it comes to handling.
Old 01-03-2020, 10:30 AM   #6
c4racer
Drives: 2016 SS Convertible
This info is not accurate. Stock tire size is 27.7" tall, not 28.7"
rears are 275-35-20 and fronts are 245-40-20, at least that is for sure what's on my car
Oh - never mind, this is for a 5th gen - is this a combined tire and wheel forum? I have a 6th gen. Different tire sizes.
https://www.tirerack.com/tires/tires...utoModClar=1SS
c4racer is offline   Reply With Quote
Old 01-03-2020, 10:56 AM   #7
Chomorro
Yea might be a combined forum. I missed out on the deal but I'm still looking to buy this square setup so now I know what tire size to get.
Old 01-03-2020, 11:03 AM   #8
c4racer
sorry - I now see there are two different tire/wheel forums on here. Carry on!!
You 5th gen guys sure have some tall tires!! haha
Old 01-03-2020, 11:14 AM   #9
Chomorro
It's good to know if I buy 6th gen used wheels my speedo will be off hahha.
Old 01-03-2020, 08:15 PM   #10
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
I have a 2014 RS 2LT and I just installed ZL1 Replicas, powder coated gloss black, wrapped in Continental Extreme Contact DWS06 tires. Wheels are a square setup 20X10" tires are 275/35/20 on all four corners. Installed last evening and I drove the car nearly 200 miles today... ZERO problems, great ride. When I was installing them last evening I checked the clearance between the sidewall and the strut, there was about 3/8" of an inch which is great. Larry
Deputy347k9 is offline   Reply With Quote
Old 01-03-2020, 08:46 PM   #11
SSammy
SSammy's Avatar
Glad you found a good deal. I love my DWS06’s so far. Good grip even in freezing temps, such a nice, smooth, quiet ride. Hope they last longer than my Pirelli’s did.
Old 01-03-2020, 08:51 PM   #12
SSammy
SSammy's Avatar
You confused the hell out me. Thought I posted on the wrong forum haha
Old 01-05-2020, 08:40 PM   #13
Chomorro
Are you guys getting significantly longer tire life with the square setup?
Old 01-06-2020, 11:36 AM   #14
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
20x10 +35 fits perfect square setup on our Camaros, i ran that square setup for a while.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
