Old 03-17-2019, 05:42 PM   #15
Overflow
Space Shuttle Aficionado
Overflow's Avatar
Originally Posted by pyroguy View Post
I agree with Ralph, any exhaust shop should be able to install them. It'll cost $400+ but any of them should be able to install them. $400 could buy a guy a nice jack, stands, pizza, and beer for his buddy to help with the install. Just remember, keep a mental not where the dip stick fit in, spray PB Blaster on the O2 sensors the night before and when you get ready to uninstall the old manifolds the next day so they don't tear any threads, torque the bolts from the middle out alternating sides as you tighten, and 10ft/lbs torque first then 18ft/lbs, heat cycle and retighten at 18 once again.
Yeah... And don't be like me and drive a week before you realize that you forgot to put the dipstick back on...
Originally Posted by Savagehenry View Post
Any advice on a solo install?
Get some rope to hold the headers while you put the first bolts in.
Overflow is offline   Reply With Quote
Old 03-17-2019, 11:05 PM   #16
fly2hip8
Drives: 2013 Camaro 2SS
Take the spark plugs out. Easier to take the spark plugs out rather than take the risk of cracking one.
fly2hip8 is offline   Reply With Quote
Old 03-17-2019, 11:23 PM   #17
Famous407
@_cherrypoppins
Famous407's Avatar
Drives: 15 Camaro 2SS/RS
Muffler Man
Muffler Man on 9305 South OBT
407 851 2988 ask for JT
I live in Orlando also
Famous407 is offline   Reply With Quote
Old 03-18-2019, 11:43 AM   #18
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
I did 4 installs without taking the plugs out and didn't have a problem.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 03-18-2019, 12:58 PM   #19
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
This is the only answer to the ops question haha.
rontammy0 is offline   Reply With Quote
Old 03-18-2019, 07:07 PM   #20
fly2hip8
Well lucky you. I hope nobody else has that problem. I was just simply trying to give some good advice. On the of chance he hits a plug with the header it will need to be replaced.
Old 03-30-2019, 09:10 PM   #21
Navajo
Drives: 2012 SS Vert
A good set of jackstands and a nice ratchet wrench. I didn’t remove the plugs either. Just make sure you see where the dipstick goes before you remove it. I took several pics.
Navajo is offline   Reply With Quote
Old 03-30-2019, 09:26 PM   #22
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Definitely.
I tapped one of my plugs so lightly while installing mine that I was sure there was no way it was damaged.
I was wrong. Nearly invisible hairline crack of the insulator. Luckily I had a new set of plugs ready.
InFiD3ViL is online now   Reply With Quote
