Old 08-10-2016, 09:10 AM   #1
sprintguy1
Drives: 45th Anniversary
Car audio swaps
I have a 2012 2SS with the factory radio. How big of a project would it be to swap to a newer deck? Thanks in advance!! Any pics are appreciated.
sprintguy1 is offline   Reply With Quote
Old 08-10-2016, 11:00 AM   #2
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
You'll have to swap with a dash kit...Metra and scoshe are the more popular kits. Ask in the radio electric section
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 08-10-2016, 12:31 PM   #3
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
FYI you can add the factory Mylink and even Nav at gen5diy.com
Since you don't have Mylink, I do think there is some cutting/splicing involved. I already had Mylink and added Nav... so it was plug and play.
Then you can always upgrade your amp, add a sub.
maddoggyusa is offline   Reply With Quote
Old 08-10-2016, 02:10 PM   #4
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Is it even worth the cost to 'upgrade' to MyLink?
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 08-10-2016, 06:14 PM   #5
CreeperRS
CreeperRS's Avatar
Drives: 20’ Chevrolet Camaro 2SS 1LE
Cool
I think it's worth it. If you want headaches go with the Metra or Scosche. There's also a way to making the OEM HU sound bad ass. So if you have the $ then by all means get one.
CreeperRS is offline   Reply With Quote
