07-14-2019, 07:13 PM | #15 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
At 77 MPH approximately 2000 RPM my oil pressure is at 2.8 Bar and it’s been that way since it was new.
07-14-2019, 07:31 PM | #16 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
07-15-2019, 03:21 AM | #17 |
Drives: 2013 Camaro ZL1 Join Date: Oct 2012
What is up with the BAR? Just PSI already...
If you hit the rev limiter while accelerating then you're fine. its designed to stop you over reving the engine. The time an engine gets fried is when you money downshift and rev up to like 10k RPM. Like doing 100MPH and downshift to 2nd by mistake. My oil pressure is 30 idle, 40-50 cold, and if its hot, then it can drop down into the 20s. Been that way for 175000 miles.
07-15-2019, 08:57 AM | #18 |
fo'shizZL1
If you can tell us how to get the ZL1 to report in psi instead of bar, that'd be great. (Of course you can change it in logging software, but it'd be nice to be able to change it on the dash.)
07-15-2019, 04:40 PM | #19 | |||
Drives: 2014 Summit White ZL1 Join Date: Oct 2018
Mine seems to be in-line with yours, or a bit higher, but I do have a Melling 10355. From what I understand, it is the OEM replacement from them. I used the stock spring that it came with, so I'm not sure if its supposed to be higher if I didn't change out the spring or shim it.
2014 Summit White ZL1- Manual
07-15-2019, 10:22 PM | #20 | |
fo'shizZL1
More filter media for better filtration and a longer change interval is the normal response, but I believe it depends on the surface area of filtration inside the filter. A longer filter doesn't necessarily mean more surface area in all cases. Plus, you have to make sure the filter bypass pressure is the same or close to the same as stock. In our case, the darn thing hangs down so low, I stopped my investigation there. LOL. On the Melling, it runs a little higher pressure than the stock LSA/DOD pump.
07-15-2019, 10:23 PM | #21 |
fo'shizZL1
Also- love the headlights! Been debating about those and some 6th gen tail lights...
07-15-2019, 10:48 PM | #22 | ||
Although, I do like the looks of the 6th Gen Style Tails for our cars, I didn't want to make it too much like a 6th Gen, I like our tail lights too.
07-16-2019, 09:03 PM | #23 |
I tried taking a picture of the LED Accents on, but they just show up white in the pic, when they have a slight blue/lavender hue to it. You can kinda see the color difference in the pics between the ones I have, and the ones for the Non-ZL1 crowd. I saw them at a Shift Sector event and thought they were for sure in the $1k+ range, but they're only around $400 or so. Wish mine were as good a quality as those.
07-17-2019, 09:29 AM | #24 |
Drives: 2014 ZL1 Join Date: Apr 2018
OP, that is bearing material. No oil change is fixing that....
07-17-2019, 12:20 PM | #25 |
I'll find out today! Hope you're wrong.
It was my first Oil Change since installing the CHE Trunnion kit.
07-17-2019, 12:41 PM | #26 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
The glitter is caused by the oil filter running in bypass mode a lot. What weight oil are you using? What oil filter?
In my drag car with a old school BBC, I use to see tons of glitter in the oil. I was using a Moroso or K&N filter. Especially tons of gold glitter whenever putting in new rockers or PRs. Here was the main problem I finally figured out - too thick oil causing way too much filter bypass time. I was using 20w50 and a racing filter - but those filters have a bypass valve. I went down a little in viscosity to a 10w40 racing oil, and switched to a WIX racing filter with no bypass. Glitter stopped instantly. Even with a brand new rocker or two there will be zero glitter. The non bypass filter is now catching it all. Now, you can't use a WIX racing filter on the street. Especially on an OE engine with tight bearings. But you can use a WIX XP, the right oil weight for your application/use/ambient.... and don't romp WOT until the oil temp equals engine temp. Visibly seeing anything in the oil means way too much filter bypass time. Filters filter in microns not visible to the eye. Even a racing filter with larger micron media gets out all the visible flecks. |
07-17-2019, 01:01 PM | #27 |
07-17-2019, 02:28 PM | #28 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
I run KN filter , love the 1” nut
