Old 05-19-2019, 08:32 AM   #15
bignaz
Drives: 2019 ZL1 1LE
Originally Posted by JCunningham View Post
do the Camaro SS script in red.
Chances are red won't happen. Unless I can get more people wanting them. Problem is I'll have to buy red resin so I'm already losing money on that just making 1. Then change everything over just to run 1. And then there's a ton of shades of red.
But me doing a run of them dapends on how much interest. I'll figure out how many each run will be and work up a schedule for batches.
Since I know someone will ask for a gm color matched version. I'll be testing one with some rattle can touch up paint to see how the finish holds up to heat and what not on the resin.
bignaz is offline   Reply With Quote
Old 05-19-2019, 08:36 AM   #16
RCF
Drives: '17 2SS, NGM, MRC, DPP; '19 F150
I’d be interested in a black set, depending on how the intake tube plug is designed.
2017 Camaro 2SS, Nightfall Grey Metallic, Magride, NPP exhaust, VS Forged VS12s in brushed clear coat (20x9 front, 20x10 rear), Michelin PS4’s (255/40 front, 285/35 rear)
RCF is offline   Reply With Quote
Old 05-19-2019, 09:15 AM   #17
Tazz3069
Tazz3069's Avatar
I am in for a set of plugs
2016 Camaro 2SS "Black Widow"
Tazz3069 is offline   Reply With Quote
Old 05-19-2019, 09:41 AM   #18
Budman51
Drives: 2023 SGM 1SS
I would also be interested in a set.
2023 1SS SGM A10 NPP
Budman51 is offline   Reply With Quote
Old 05-19-2019, 02:00 PM   #19
AD17SS1LE
AD17SS1LE's Avatar
Drives: 2017 Camaro SS 1LE
I am also in for set, any color but black if you can.
2017 Camaro SS 1LE
Pray ported TB/IM
TSP 1 7/8 Long tube headers w catted con pipes
Taylor plug wires
Mishimoto oil cooler
Elite X2 catch can
AD17SS1LE is offline   Reply With Quote
Old 05-19-2019, 02:05 PM   #20
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
I would like a black set.
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 05-19-2019, 04:48 PM   #21
bignaz
So tomorrow im going to fun a final firewall block off plate prototype run. If all goes well with that i can start on those. Intake plugs will fallow. First set will be black and just say Camaro. Might do one small tweak to the firewall plug to protect it from over tightening of the mounting bolt.
That being said intake plugs are going to be designed for the oem ss/zl1 intake. As those are the only intakes on hand. Had a rotofab but it had the sound tube delete. V6 intake plugs i gotta meet up with someone and get some measurements. The plugs should work with intakes that use the oem sound tube stuff but i have no idea of testing it since i dont have any.
Colors i had on hand are Black and Gray. I can get other colors but it will either cost more since i have to buy the resin or get enough interest in enough to offset the cost of the resin.
Old 05-19-2019, 10:41 PM   #22
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
iv had stock, Cold Air inductions, and Rotofab they all are just a 1"hole to fill.
Old 05-20-2019, 08:46 AM   #23
CamaroVille
Drives: 2018 Camaro 2SS M6
I am interested in a black intake plug.
Thanks
Rick
2018 Camaro 2SS M6 NPP
HBM w/Black Metallic Rally Stripes
Built 6/21/18 -- Purchased 7/28/18
CamaroVille is offline   Reply With Quote
Old 05-20-2019, 09:26 AM   #24
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
I'm in for a firewall plug. Looks great!
Old 05-20-2019, 12:40 PM   #25
bignaz
Not happy with how one part turned out. So I'll be doing another test tomorrow. Going to change some support around and see if this improves it. Working on an intake plug prototype right now. So delayed a day but getting closer
Old 05-20-2019, 12:48 PM   #26
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
Very cool! I'd like one too.
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 05-20-2019, 02:19 PM   #27
bignaz
Haven't did a final trim on the firewall plate so has some tiny nubs from supports. The intake tube plug should be fine just cramming it in and use a clamp to secure but it's threaded for an internal plug to secure it. Haven't cleaned the plugs. Sis some sanding on the top so I can do some thermal test and needed a lapped surface so that's what all the white dust is on the threads. I'll changed the plug design around a little bit. It will be a single peice I just made it a 2 peice to do some pull test on. And see how strong the mounting flange is.
Projected finish date should be on track for Friday. Possibly sooner depending on how some test go tomorrow.
Old 05-20-2019, 05:24 PM   #28
bignaz
Plug for the SS intake
