View Poll Results: Does your A8 car display shuddering issues? | |||
Yes | 115 | 72.78% | |
No | 43 | 27.22% | |
Voters: 158. You may not vote on this poll |
Thread Tools |
12-05-2018, 12:51 AM | #43 | |
The initial workaround was a triple flush of the trans fluid, followed by torque converter replacement. This was finally deemed insufficient by GM, and a permanent engineering solution was promised to be made available in Q1 2019. Many owners managed to successfully fix it by reprogramming the trans (and flushing the fluid, if needed), but this voids the powertrain warranty and may not help if the physical damage to the torque converter was already done. (The A8/A10 transmission control module software is protected on 2017+ models, and the encryption has to be cracked first in order to upload a new tune, which will definitely be detected by a dealership.)
12-15-2018, 07:41 AM | #44 |
Drives: 2016 2ss Hyper Blue Join Date: Sep 2009
2016 here. Mine started right around 9500 miles. Took it in for the flush and so far so good at a little over 12000 miles. I'm not holding my breath that it will last though especially since the rear differential is acting up again. I had the same problem with that that some folks here had and took that in for the flush at 1200 miles and now it's back. So off to the dealership I go.....
2016 2SS Hyper Blue, Auto, Mag ride, NPP, Black interior
04-03-2019, 01:50 PM | #45 |
Drives: 2018 Camaro Hyper Blue 2SS Join Date: Mar 2019
Bought mine used with 20k on it and it has the "shudder" when it's going from a v4 to a v6, don't really notice it going from 6 to 4..
Don't know how long it was doing it before I got it. I was sure what it was until I found it in the forums... |
04-17-2019, 06:44 AM | #46 |
Drives: Camaro SS 2018 Convertible Join Date: Apr 2019
04-19-2019, 08:24 PM | #47 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
The bulliten specifically states what the dealer needs to do. If they choose not to follow that then I'd find another dealer
