02-26-2018, 08:29 PM | #1 |
Drives: 2019 ZL1 1LE Join Date: Mar 2014
Need a good spoiler give me some recommendations.
So I'm turning the Camaro into a track car. So I'm in need of something to make some down force. I got the stock on from the RS package but looking for something that can bolt up to the stock holes.
02-27-2018, 06:00 PM | #2 |
Drives: 2018 ZLE Join Date: Jul 2014
i never could find one myself sadly
02-28-2018, 06:02 AM | #3 |
Drives: 2015 Z/22 Join Date: Aug 2015
You could try the Z28 replica spoiler by Aero Sport Concepts which uses the existing holes; he also makes extensions for said spoiler. If you want big-time down force maybe check out APR's wing.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
