08-30-2017, 11:00 PM | #71 | |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Tip for the spring loaded pins, pull fast once the pin is depressed, that way you don't have to depress the pins twice to fully remove.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
10-04-2017, 10:00 AM | #72 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Just checked in with MGW:
"hi, we are still in design . the initial design we had just would not fit in the constraints of the console and driveshaft. its been a huge pain in the ass. We are hoping to have an answer one way or another soon. thanks" I'm not in a hurry, so I don't mind waiting. He did say that they would put a notice up on the website if they decided to abandon the project. He knows there are tons of fans waiting, and they know about the forums but he says they will not release a half assed product. It's gotta be up to their quality, or not at all. Don't lose hope!
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
03-16-2018, 01:19 PM | #73 |
Bumping this back up with the bad news. Sucks cause I had one in my C7 and it was a freakin' work of art. Rifle bolt slick.
From MGW themselves: "Sadly we are not going to offer one. We just could not get enough clearance between the driveshaft and tunnel for a race spec shifter."
