TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 03-19-2014, 09:03 AM   #1
bignaz
Drives: 2019 ZL1 1LE
Vararam gap Question
Does this look OK or should I go for a bigger gap. If so how did you guys open it up more.
bignaz is offline   Reply With Quote
Old 03-19-2014, 09:38 AM   #2
KMPrenger
KMPrenger's Avatar
If your keyfob fits (if even slighly snug on one side) you are good to go. Just check it from time to time to make sure it isn't closing up more.
Mine stays about like that...the gap is usually just a bit bigger than the key fob.
Old 03-19-2014, 11:06 AM   #3
bignaz
Got a pic of a key fob on yours. Mines pretty tight. Just seems like the cap is to small. So far it never moved everything is where it was when installed.
Old 03-19-2014, 02:01 PM   #4
The_Grinch
The_Grinch's Avatar
Drives: car
Mine was like that, then after I installed the Vmax Isolator it got a little larger as the angle is just a bit different.
The_Grinch is offline   Reply With Quote
Old 03-19-2014, 09:47 PM   #5
KMPrenger
KMPrenger's Avatar
Here is an old shot of mine
