06-17-2020, 09:41 AM | #1 |
Drives: 2017 Black 1LE Join Date: Feb 2017
Noisy Sway Bar End Link Solution
Hey,
So I made this video showing how to swap out the GM sway bar end links. I have heard many other 6th Gen owners having issues with their end links as well. The nut on the passenger side was backing out after I would tighten it up, causing a "clunking" noise going over bumps. If you are having this problem these BMR end links may be your solution! Also have heard of these same parts actually bending under hard driving. Not what you want! The BMR links are also adjustable, for all my hardcore track drivers. LINK: https://youtu.be/q-Qv6joDGvo PARTS: https://www.summitracing.com/parts/BMR-ELK016
17' Black SS 1LE with PDR
Delivered…05/17/17 A dream come true!! 02' Silverado 5.3 Cammed Lowered single cab, daily driver |
06-17-2020, 09:01 PM | #2 |
Drives: 2018 ZL1 Join Date: Dec 2017
I had the same issue, both of mine had started making noise for the second time, recently installed the BMR’s! Hoping to be be finished with them, so far so good! Don’t know to rotate image.
06-18-2020, 07:00 PM | #3 |
Yes it seems like it’s a common problem. I hope the same and hope I never have to mess with them again! Good luck to you.
