Old 11-29-2023, 12:51 PM   #1
Osbornsm
Drives: 2018 SS 1LE
Question Caliper Refresh
Been doing HPDE days for 20 years and I've never refreshed my calipers.
  • My piston boots are toast, and will be again if i replace them.
  • I run 1mm TI shims to keep heat out of the caliper.
  • I run the track ducts in the front.
1. How much would one charge for a caliper refresh?
2. What's involved?
Thanks for your input,
~ Sean
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 11-29-2023, 07:38 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Its relatively easy job just pull the calipers, use compressed air to pop the pistons then remove boots an seals, and then reverse the process. Rock Auto, Racing Brake, and Giro Disc have the seals an boots. It’s also a good time to get vented pistons if not already installed. Rock Auto for OEM pistons and Racing Brake for the scalloped style piston.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is online now   Reply With Quote
Old 11-30-2023, 05:29 AM   #3
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
For the stock SS 1LE calipers (J6M), you can use the J56 Corvette vented pistons (PN 23242510) which are the correct length for that caliper. You need one kit per caliper. That PN kit comes with the pressure seals. PN 19207044 is the kit for dust seals (one kit per caliper).
For the J6H (both regular and BCD size front calipers), you use the same dust seal PN but use 19207043 for the longer vented pistons, one kit per caliper.
RUQWIKR is offline   Reply With Quote
Old 11-30-2023, 05:32 AM   #4
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I've never done a caliper rebuild before but with the correct info, parts and tools I was able to rebuilt my fronts with vented pistons and high temp dust boots and they work so well I no longer run Ti shims.
Whether you do it yourself or have a shop do it, you definitely want the vented pistons. Some don't like the RB high temp boots because they are not to be exposed to brake fluid, but I didn't have any issues following the instructions and they are holding up great.
If you're interested in more info let me know.
Old 12-02-2023, 08:37 PM   #5
Badmojo
aka BeastZL1
Badmojo's Avatar
I did a video when I rebuilt mine.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 01-10-2024, 02:20 PM   #6
Osbornsm
Drives: 2018 SS 1LE
Please excuse the delay, but really good video!!
It showed me i don't have the confidence to do it.
I'll have a local shop refresh, if at all
Old 01-10-2024, 02:33 PM   #7
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I replaced my OEM dust boots with the high temp ones and they've been great. The OEM ones were cooked after a few trackdays.
Christian1LE is offline   Reply With Quote
Old 01-16-2024, 12:45 PM   #8
Badmojo
aka BeastZL1
Badmojo's Avatar
Thanks for the feedback and glad it helped you make a decision.
2019 Camaro ZL1 1LE
