08-06-2020, 08:49 AM | #57 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Order Status = Back ordered
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
08-16-2020, 12:32 PM | #58 |
Drives: 2019 Camaro SS Join Date: Jun 2019
Updated op with links to extension harness and brake booster fitting
2019 Camaro 1SS A10 River Side Blue
Max effort tuning llc Rotofab dry, ported msd, nw 103mm Tb , speed engineering 2” headers, velossa tech,ati ud, aerospace front brakes, and flex fuel |
08-16-2020, 01:52 PM | #59 |
Drives: 2018 Camaro SS/1LE Join Date: Jan 2018
Another option for brake booster port- if u want a similar style port so u don’t have to change anything on brake booster hose... the plastic end on the brake booster hose is 1/2” od. So I ordered a 1/2” od to 3/8” npt “push to connect” fitting. It’s basically the same setup as the stock manifold. There is both dot and non dot styles for these. Dot style just has a tube that goes in the middle so the connection can’t move around.. they use these kind of fittings on air brakes for big rigs so I think they can hold up for what we’re looking for... I also noticed that the inside diameter of the booster hose is 3/8”, but the smallest opening in the whole line is 1/4”... so whatever u do decide to go with, just make sure ur still getting the same air flow and have at the least 1/4” inside diameter with whatever u add. 3/8” ID would be more ideal though.. DO AT YOUR OWN RISK! I have not got my fittings yet but I have used them before for similar ocasions
08-16-2020, 04:40 PM | #60 | |
08-16-2020, 04:42 PM | #61 |
How is the low end torque? Like real low 1500-2000rpm?
08-16-2020, 05:50 PM | #62 |
-dot approved-
Eaton Weatherhead 1868X8 Brass CA360 D.O.T. Air Brake Tube Fitting, Male Connector, 3/8" NPT Male x 1/2" Tube OD https://www.amazon.com/dp/B00BKFA6PS..._rABoFbX6ZPG4Z -Non dot- Tailonz Pneumatic 304 Stainless Steel Male Straight 1/2 Inch Tube OD x 3/8 Inch NPT Thread Push to Connect Fittings PC-1/2-N3 (Pack of 2) https://www.amazon.com/dp/B0894BWJB2..._UwBoFb5NX1J8W I ordered the dot Approved one... it should b here in a few days.. I’ll post how good it works when it comes in.. I had also bought a spare brake booster hose so I can test all my fittings before I take things apart. That way if something is wrong I’ll know before I go through the hassle of removing stock im |
08-17-2020, 09:02 AM | #63 |
Drives: 16 camaro 2ss Join Date: Aug 2020
Can you remove the current lines and just take a 3/8 hose and connect everything instead of hacking apart your current booster/pcv lines? I mean it fits so would their be an issue?
08-17-2020, 10:18 AM | #64 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Great info! I'd like to see some datalogs with this on an otherwise stock car with no tune to understand if there are any unwanted trade-offs. I don't plan to touch the calibration in mine until 2022!
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
08-17-2020, 02:16 PM | #65 |
This is what the booster hose looks like, I bought an extra just incase I decided to hack it up.. it’s heat treated and hard like plastic to hold its shape so it doesn’t kink when trying to route it. It’s not a straight shot between connections. So if u just ran your own hose u would have to b careful that it doesn’t kink.. but then u also have to figure out how to connect it to the main hose.. best bet is to either buy an extra one of these to hack the end off ($15) to just do a regular 3/8” fitting to the manifold, or buy the 1/2” push to connect fitting I mentioned
08-17-2020, 07:49 PM | #66 |
Camaro6 newbie
Drives: 2020 Riverside Blue Metallic 2SS Join Date: Feb 2020
Guys,
I'm a parts guy at a Chevy dealership...ordered my LT2 IM on August 3rd and I have NO idea when I'm getting it. ToxicJon, thank you so much for the information! Like most all of you guys, can't wait to replace my Pray Performance ported LT1 intake with this bad boy and see what difference it makes on my car! |
08-19-2020, 11:04 AM | #67 |
Drives: 2011 2SS/RS & 2017 1SS Join Date: Apr 2011
GPI is doing all the modifications needed to just bolt this sucker on. Heard they had a large batch come in a few days ago, but have another large batch on order. Basically, just get in line!
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE Built/Tuned by Me 2017 Chevrolet Camaro 1SS Auto 9.29 @144.57mph ALL MOTOR SBE #TEAMGPI Gwatney Performance Innovation |
08-19-2020, 11:12 AM | #68 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
This! I want to be sure it's okay to run this without a tune before buying it. How do we know the car isn't running rich or lean? GPI tested it on a tuned car (I know the tune wasn't changed for the intake) not sure if that affects it not getting a CEL or running lean or rich.
08-19-2020, 01:47 PM | #69 | |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
08-19-2020, 02:09 PM | #70 | |
Drives: 2019 Camaro 2SS Vert Join Date: Apr 2020
