Old 12-21-2020, 11:49 AM   #169
SilverSurfer18
SilverSurfer18's Avatar
Drives: 2021 1SS Camaro
Originally Posted by bjbonentte View Post
Finished product
Did you modify the brake booster part yourself? Have any links, pics or tips?
SilverSurfer18 is offline   Reply With Quote
Old 12-21-2020, 12:01 PM   #170
bjbonentte
Drives: 2019 Chevrolet Camaro
Ya it was pretty easy. Somewhere on this thread is a link to lowes for the brake booster fitting. I drilled and taped the hole with a 1/2 npt tap and threaded the fitting in and good to go.
bjbonentte is offline   Reply With Quote
Old 12-21-2020, 12:02 PM   #171
s346k
s346k's Avatar
Drives: like an old lady
Finished product
what did you do for the port on the front of the intake manifold?
Old 12-21-2020, 12:05 PM   #172
bjbonentte
I have a JLT catch can. So I did not have to modify the stock pcv line. You can cut the connectors off the stock hose and use those with a piece of hose to extend that pretty easy.
Old 12-21-2020, 12:52 PM   #173
Redlinez
Shifts under load
Redlinez's Avatar
I just installed my LT2. Completely changed the car. I Love it. I also have Soler ported TB, GMPP intake.
I modified the underside of the intake myself. Took about 30 minutes to do that and a little over an hour to install on the car.
I purchased my intake from Summit and my engine cover from GM Parts outlet.
Intake: 187.99
Map extension: 29.99
Cover: 110.01
https://www.summitracing.com/parts/ado-12697714
https://www.summitracing.com/parts/icb-wemap40-24
https://www.gmpartsoutlet.net/oem-pa...cover-12705108
What fitting did you use on the rear for vacuum?
22 Suzuki GSX-S 1000GT blue
Old 12-21-2020, 01:12 PM   #174
SilverSurfer18
On page 5 there is an amazon link for it. Just purchased mine as well.
Old 12-21-2020, 06:06 PM   #175
s346k
s346k's Avatar
the catch can didn't intercept that vacuum line? you left the port open on the intake manifold?
Old 12-22-2020, 08:23 AM   #176
bjbonentte
In that pic it just wasn't connected. it is dangling bellow.
Old 12-23-2020, 12:34 AM   #177
s346k
s346k's Avatar
10-4. simply clarifying. i had an LT2 intake on my car 3 months ago, this info is not for me haha.
Old 01-03-2021, 09:50 AM   #178
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
If this is a repeat I apologizw but an interesting article on the LT2 and its differences from the LT1. Minimal in some areas, most differences are the in the intake, dry sump, exhaust headers. The cam timing is different too.
https://www.midenginecorvetteforum.c...ngray%E2%80%9D
Old 01-03-2021, 10:03 AM   #179
s346k
s346k's Avatar
if i recall correctly, LT2 has the same rotating assembly and cylinder heads as LT1. different cam profile and external hardware.
Old 01-03-2021, 11:37 AM   #180
Paintslinger16
Two Lane Blacktop
Paintslinger16's Avatar
Drives: '18 Camaro 2SS
I wonder if they will ever put the new cam in the Camaro, LT1 seems like would be a easy bump in HP, and without the dry sump still less then Vette.
i would swap neighbors before i swapped exhaust
Paintslinger16 is offline   Reply With Quote
Old 01-04-2021, 05:17 PM   #181
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Its spelled out very clearly in the article which is very detailed.
Old 01-05-2021, 07:55 PM   #182
MVPxD
MVPxD's Avatar
Drives: 2021 Camaro LT1
Porting?
Anyone know where else I can find one ported? Only place i see it ported is on GPI but comes out to more than $700...
Or would anyone with the knowledge to do so here, port it for me? Of course I'd pay. I just don't know how. I'm in NJ.
MVPxD is offline   Reply With Quote
