Old 01-03-2019, 05:34 PM   #1
UK Basketball Rocks
UK Basketball Rocks's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE
SS 1LE Rear Spoiler
Im curious if there are any aftermarket Rear Spoilers that can replace the 1LE Rear Spoiler and match up to the same mounting holes?
UK Basketball Rocks is offline   Reply With Quote
Old 01-03-2019, 07:46 PM   #2
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
the 1LE rear spoiler is held down by double sided tape not sure if there are holes. You could go with the ZL1/1LE spoiler
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 01-03-2019, 08:16 PM   #3
zr1chris
zr1chris's Avatar
Drives: 2018 Camaro 1SS/1LE
I thought it was just the corner pieces that are held with the double sided tape.... ?
zr1chris is offline   Reply With Quote
Old 01-03-2019, 09:35 PM   #4
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I've only found 1 so far and don't know if it's any good, but it is inexpensive
https://www.ebay.com/itm/1LE-Extende...L/323496840212
carguy55 is online now   Reply With Quote
Old 01-03-2019, 09:56 PM   #5
UK Basketball Rocks
Thats what I thought.
Old 01-03-2019, 09:56 PM   #6
UK Basketball Rocks
Whats it look like?
Old 01-03-2019, 10:30 PM   #7
Ryanbabz71
Ryanbabz71's Avatar
Whats it look like?
Ryan B.
Ryan
Old 01-04-2019, 12:35 PM   #8
PNW1LE
Drives: 2018 ss 1le
Wouldn't you basically need a donor trunk from an SS car at that point?
PNW1LE is offline   Reply With Quote
Old 01-04-2019, 02:30 PM   #9
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Yes, any of the coupe decklids with the "triple stanchion" wing on it will work (Non-1LE SS, ZL1, and I think even some of the higher-optioned I4 and V6 cars might have it).
There are 9 holes in the SS 1LE decklid for the OE spoiler: 3 for threaded studs on the LH side, 3 slots for clips in the middle, and 3 more threaded stud holes on the RH side. Only 2 of the existing 9 holes will line up (the middle threaded stud hole on each side). The others would need to be sealed somehow and then you'd have 4 more holes to punch out. Here's a crappy drawing that gives a rough representation of how it's laid out. Black are existing holes in the SS 1LE decklid and green are the ZL1 1LE mounting locations.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 01-04-2019, 05:05 PM   #10
carguy55
carguy55's Avatar
Since the holes in the 1LE trunk are different than the SS & ZL1 trunk, you need a donor trunk or have to drill extra holes and fill/cover some others. The donor or new trunk should be from a 2017 (or later) SS or ZL1 since they have the extra reinforcement same as the ZLE trunk if you want to use the wing. I have also heard the trunk support rods are different to support the extra weight of the big wing.
Old 01-04-2019, 05:07 PM   #11
carguy55
carguy55's Avatar
Old 01-04-2019, 08:21 PM   #12
UK Basketball Rocks
Originally Posted by carguy55 View Post
I guess im shit out of luck, not getting another trunk lid and not drilling more holes..
Old 01-04-2019, 10:20 PM   #13
carguy55
carguy55's Avatar
This one looks like it's actually made for the 1LE
https://extremeonlinestore.com/colle...12590246625381
