01-02-2019, 06:32 PM | #1 |
Drives: 2017 Camaro 1LE Join Date: May 2016
Baffled Oil Pan
Hello Everyone,
Ive been looking around for an oil pan baffle setup for are cars however I haven't been able to turn anything up. Yes I know a dry sump will be ideal however they can be very very expensive. The closes thing I can find so far is a "GM GEN V LT ROAD-RACE OIL PAN BAFFLE" made by Holley however its designed to work with the Holley GM Gen V Retro-fit Oil Pan. Holley Oil Pan Baffle: https://www.holley.com/products/acce...s/parts/302-30 GM Gen V Retro-fit Oil Pan: https://www.holley.com/products/ls_p...s/parts/302-20 If anyone has any info to chime on with it would be greatly appreciated!
2017 Camaro SS 1LE
Instagram: @Destroyer_1LE Sponsor: Tires: Michelin, Wrap: Protective Film Solutions, Wheels: APEX RACE PARTS |
01-02-2019, 06:48 PM | #2 |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
I haven’t seen any dip in minimum oil pressure in sustained 1.5g running non-dot slicks on track. Seems 10quarts is enough to keep oil pump pickup submerged on track. Don’t get me wrong, I had a baffled oil pan on my Boxster S because it was needed. Seems we don’t need one. I know of a ton of LS3’s that had oil starvation issues on track, but those also had much less oil capacity, 2-4 quarts less oil depending on application.
Interesting aside- do you know what Porsche Did to the GT4 motor when they went to homoligate the GT4 Club Sport for FIA international racing where it will only race on slicks? Overfilled the stock system by 1 quart, and recalibrated the electronic dipstick. |
01-02-2019, 11:34 PM | #3 | |
2017 Camaro SS 1LE
01-03-2019, 03:10 AM | #4 |
Drives: 22 ZL1 1LE Join Date: Nov 2014
You should have zero issues with oil starvation! The GM Engineers designed the car extremely well for Track Use
01-03-2019, 03:11 AM | #5 | |
01-03-2019, 06:18 AM | #6 |
Drives: '18 1SS 1LE Join Date: Sep 2017
Install an oil accumulator.
'18 1SS 1LE Black, PDR
01-03-2019, 09:16 AM | #7 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
It all comes down to the car. On my R53 MINI and Lotus Exige S, yes baffled pans were wise when running Hoosier's. My turbo Miata didn't need one however. Anecdotally, my two cars that needed them were transverse and the two that don't are longitudinally mounted engines.
01-03-2019, 09:32 AM | #8 |
Daily Driven 1LE
Drives: 2018 1SS 1LE Join Date: May 2018
Reason #3,427 that GM voided a warranty for engine failure - user installed oil pan baffle. These cars have been going for several years now, hold 10 quarts of oil, and have had no reported oiling issues that I've seen.
2018 1SS 1LE
01-03-2019, 10:06 AM | #9 |
Right now Im running PS4S's and those are a 300tw tire and I'm already holding a lot of speed. Ive driven on Cup 2's and they are well worth the money.
2017 Camaro SS 1LE
01-03-2019, 10:09 AM | #10 |
I agree with what your saying just looking around as when these cars first came out everyone wanted them to have dry sump or at least a baffled oil pan. When my car is full track prepped it holds 11 quarts
2017 Camaro SS 1LE
01-04-2019, 02:43 PM | #11 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Not aware of anyone wanting dry sump with LT1 ever. Corvettes excepted. Everyone did want one with LS3 but that's a very different animal. You wont get tons of speed increase on cup2s vs G3s. Their grip is almost identical plus/minus. Save your money Of course slicks will up the Gs but then again Randy Pobst did some VERY fast laps on a Roval in a 1le with no ill effects. Id expect a seasoned amateur to match his pace with slicks on. More or less. If you want peace of mind (read: drive line warranty) do NOT touch oiling systems as GM will invalidate the warranty for sure. Seen it happen many times with various cars over the years. Lastly, given what you state as oil capacity when your car is "track prepped" at 11 quarts it seems you are OVERFILLING by a quart which is a no no for LT1. It is recommended for various other GM motors incl Camaro's LS motor, but NOT for LT1. Hope this helps. Cheers! |
01-04-2019, 04:05 PM | #12 |
Hot Dog
You mis-read your performance supplement? V6 gets +1 quart for track time, but the V8 does not. ...unless you have a non-stock oiling system.
01-04-2019, 05:47 PM | #13 |
Min oil pressure on my friends modified ZLE on slicks was 29 and he hit 1.54G on that lap according to the PDR data.
My stock 1LE on the same track hit a min of 36.5 @ 1.20G. Neither of these low pressures were on the same lap as the max Gs |
01-04-2019, 06:21 PM | #14 |
