04-23-2018, 04:37 PM | #15 |
That is Rolling out!
2016 NFG 1SS A8
04-23-2018, 05:13 PM | #16 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Thanks
Kinda lame post without a new best ET lol. but its something. Just mainly wanted to spread the news about what I believe shows the pulley is worth a little bit. Maybe not worth 450-500 bucks but it all adds up. |
04-24-2018, 09:18 AM | #17 |
Drives: 2016 CAMARO 2SS Join Date: Apr 2017
How was the DA in comparison?
2016 SS A8 STOCK 12.35@113.6 DA 1956
PRAY E85 TUNE,PRAY PORTED IM/TB,ROTOFAB DRY, DRAG PACK 11.33@121.8 DA 1248 PRAY PORTED MSD, 2" TSP LT's 11.38@122.4 DA 3664 GFORCE DRIVESHAFT,LME 174 T-STAT,ATI UDP up next... |
04-24-2018, 10:22 AM | #18 |
My best prior at different track in about -150 was 125.3.
I went 124.5 at this same track last year in +1100. It was +300 for this pass and 126.5. 60 ft was nearly identical. I picked up a bit of mph. Not sure bout ET maybe a touch. It’s hard to compare different days etc. |
04-24-2018, 12:48 PM | #19 | |
04-24-2018, 12:59 PM | #20 |
04-24-2018, 11:33 PM | #21 |
Drives: 16 camaro ss Join Date: Sep 2017
Ultrazl1 you think you gained .07 from the udp?
04-25-2018, 12:14 AM | #22 |
Without the same 60 it’s hard to say. Without being same track same day anything is hard to say for sure. All I know is that the car has never trapped over 125.3 even in better air than this. I think the pulley is good for a small gain. About 1-1.5 mph. ET I’m not sure. Maybe a small amount. I’m guessing the gains are in the upper rpm range. Let’s the motor spin a bit easier. Improves balance/harmonics a bit.
Like I said might not be worth the money to some. But it does help a little I believe. With the data I have exact amounts is impossible to know for sure. All I know right now is I picked up some mph and it’s definitely not slower. |
04-27-2018, 08:57 AM | #23 |
Drives: 2016 2ss Camaro Join Date: Oct 2013
Man your car is FAST! Great run. Did you use the ARP bolt or go back with a gm?
HBM 2016 2SS A8 NPP
427 Pray Head/Cam/Converter, Pray Ported Highram, 103mm TB, Pray Tuned, 3030 Drag Pack, Roark OTR CAI, TSP Headers, E85, UDP Best times 1/4 n/a 9.23@146.96, 1/8 5.91@118 |
04-27-2018, 09:22 AM | #24 | |
ARP bolt does not work with this pulley. A different part number might idk https://www.camaro6.com/forums/showthread.php?t=524649 |
04-30-2018, 08:51 AM | #25 |
Drives: 2013 SS Join Date: May 2013
Very nice!
05-07-2018, 09:55 PM | #26 |
Drives: 2017 Camaro 1SS A8 Join Date: Jan 2017
I just hope when my tune is done I will be able to trap 125+. Great times mang.
05-07-2018, 10:53 PM | #27 | |
I wouldn’t expect it first time out. This car has a lot of time and tuning in it. You’ll probably be low 120s first time out as a guess but idk your whole setup. Forgot to post. Someone got a 126.4 pass on vid from that day. Here it is. https://m.youtube.com/watch?v=KNy_GFpcayE |
05-08-2018, 01:28 PM | #28 |
Drives: 2016 2SS Join Date: Jul 2016
Good work brother, great passes.
Spinning won't help your mph much of any in these cars. Once you spin the car will short shift the 1/2 which only hurts. But that could be why your 1/2 shift rpm is short. Launching in Manual and bumping back into Auto may be the only correction to spinning a little and having it not hurt you. I think a little wheel speed with the stock converter could help if you could get the shift points worked out. 26+mph on the back half is scooting. That is where the MSD shines.
