Old 10-22-2019, 09:31 AM   #15
Camarentino
Camarentino's Avatar
Drives: 2018 Camaro 1SS 1LE
Stupid question but does amplifying the stock speakers on a 1LE require all the speakers to be re wired?
2018 Camaro 1SS 1LE w/PDR Summit White
KN intake-MBRP cb- 2nd cat deletes- ACS sides- iroc Z spoiler- Eibach Pro- Katech 95TB- MSD Manifold-GM strut bar- Custom tune by Arun Ahuja @ CCPERF.ca
Camarentino is offline   Reply With Quote
Old 10-22-2019, 02:30 PM   #16
oOKhanhOo
Drives: 2018 SS 1LE
No, you can tap in at the radio tuner behind the glove box. its a B*tch to get to. I'd recommend getting the PAC Audio or NavTV module so you'll get clean and flat signals.
oOKhanhOo is offline   Reply With Quote
Old 10-22-2019, 04:44 PM   #17
Camarentino
Oh great thanks
Old 10-25-2019, 09:58 AM   #18
Redlinez
Shifts under load
Redlinez's Avatar
What kind of money are those Hybrid Tech stock replacement speakers? Or which series should I be looking at?
22 Suzuki GSX-S 1000GT blue
Old 11-10-2019, 04:48 PM   #19
Camarentino
This gets you amplified chimes and turn signals correct?
Old 12-19-2019, 11:47 PM   #20
Coded4SS
Drives: 2020 1SS 1le
Would like to know this too
And when we say amplified are we saying 5-10 on a 0-10 scale. Or 5-6
Coded4SS is offline   Reply With Quote
Old 12-20-2019, 05:13 PM   #21
oOKhanhOo
Drives: 2018 SS 1LE
W/ the module, you can adjust the chime volume. W/o, the chime and signal will be amplified depending on the aftermarket amp gain you set it at.
Old 04-05-2020, 12:17 AM   #22
eaglesfan2006
Drives: 2019 1SS 1LE Riverside Blue
Looking to add an amp to the factory system (1LE so no stock amp), is it not possible to tap in behind the head unit? The more digging I do the harder this seems to get.
Adding a Kenwood Excelon 301-4 amp. Down the line I’m going to replace to door speakers.
eaglesfan2006 is offline   Reply With Quote
1le, door speakers
