Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 07-04-2019, 12:50 PM   #1
vestalsin
vestalsin's Avatar
Drives: 2010 Camaro RS Inferno Orange
VVT Solenoid
So I am a bit confused but where exactly is the variable valve timing solenoid on a 2010 camaro LLT? And are there mare than one? I see I can buy it for my car however can’t find in my Haynes manual. Is it the same as the camshaft actuator? Any help with this would be greatly appreciated.
“The inside of the old Camaro smelled like asphalt and desire, gasoline and dreams.”
vestalsin is offline   Reply With Quote
Old 07-04-2019, 06:29 PM   #2
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
Theres a combination of parts for the system to work but the actuator/phaser is on the gear end of the camshaft.
I’m a fan of VVT, it really broadens the power band for street/strip cam setups, thought it may not work for monster lift race cams. This link has a decent description of the parts https://www.onallcylinders.com/2017/...-an-ls-engine/
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 08-01-2019, 07:54 PM   #3
JJPlace1
JJPlace1's Avatar
Drives: 2010 2LT Victory Red
There are 4 total . Each cam has one and they are inserted in the front of the engine .
Previous Vehicles
1970 Impala 2D 350/300
1972 Buick GS 350
1967 Pontiac Firebird 326
1969 Chevelle SS 396/375 I really miss this one
1966 Chevelle SS 396/350
1978 Plymouth Fury 440
1982 VW Scirocco ( Got married )
1987 VW Scirocco
1992 Ford Taurus V6
1996 Dodge Intrepid
2002 Dodge Intrepid
2002 Mercedes ML500
2010 Camaro 2LT
JJPlace1 is offline   Reply With Quote
Old 08-06-2019, 05:45 AM   #4
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The L99 has one cam.
Old 08-11-2019, 08:08 PM   #5
JJPlace1
JJPlace1's Avatar
This engine has 4 cams .
Previous Vehicles
1972 Buick GS 350
1987 VW Scirocco
1992 Ford Taurus V6
1996 Dodge Intrepid
2002 Dodge Intrepid
2002 Mercedes ML500
2010 Camaro 2LT
Old 08-12-2019, 04:48 AM   #6
fhrex
fhrex's Avatar
Drives: 2011 Camaro 2LT/RS
the solenoids and actuators are different components. the solenoids are external, the actuators internal. there are 2 intake solenoids and 2 exhaust solenoids, one of each for each bank. there are 4 cam actuators, one for each cam.
fhrex is offline   Reply With Quote
