06-08-2019, 10:22 AM | #1 |
Drives: 2010 Camaro RS Inferno Orange Join Date: May 2015
ECU Swap
Got a question for you all. So my Camaro has been having problems for a long while now, multiple random codes. So in an effort to process and eliminate I got a ECU from another Camaro, same year, engine etc. Buddy of mine has a good car scanner that can do just about anything but wouldn’t let him change the vin. Because I couldn’t get the key that came from that car I was going to try and relearn my key using the pass key 3 relearn procedure however it does not work. I know that passkey 3 works off of the BCU of the car and I am thinking because the vin on this ecu doesn’t match currently it won’t initiate the key relearn. Has anyone put a different ecu in their car and if so what process did you do? If I can get this one to match my car than it might eliminate the problems I have been having, or at least let me know that my original ecu is not bad and the problems lie elsewhere.
“The inside of the old Camaro smelled like asphalt and desire, gasoline and dreams.” |
06-08-2019, 02:34 PM | #2 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i think any tuning shop can handle it but if you don't have one pcm of nc is pretty good at flashing and tuning.i have use them in the past.
i actually live in mooresville nc,there is a fair amount of tuned cars rolling around my town done by them.topnotch! http://www.pcmofnc.com/ |
