Old 03-11-2017, 02:42 PM   #1
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
Drives: 2016 Camaro 1SS
Exclamation 20mm Spacers Making Me Nervous
Never done anything like this to a car, worried about sending that much RWHP to 20mm spacers.
Are there any risks associated with installing these to a 2016 1SS? I've heard nightmare stories of wheels blowing off.
I should also note I drive the car pretty hard, I don't want to be nervous about using launch control or spinning the wheels.
All I've done is NPP exhaust and Cold Air, so specs are pretty darn close to stock
Link
http://www.ebay.com/itm/281813436620
GAHDOOSH
2016 1SS 6.2L LT1 Manual 6-Speed, Front Emblem Blackout, Rear Bowtie Delete, Side emblem delete, Phastek Side Marker Tint, GM Black Taillights, $23.57 of Premium Gas this morning
GAHDOOSH is offline   Reply With Quote
Old 03-11-2017, 03:43 PM   #2
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
I run 3mm spacers and I'm super nervous. I'm not entirely sure why you're trying to run such a large spacer but, suffice to say, if you drive your car hard on a regular basis, I'd avoid spacers and instead opt to get wider wheels.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 03-11-2017, 04:14 PM   #3
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Why do you need them? Don't do it, at some point just buy a set of wheel with the right offset to get the stance your looking for.
Old 03-11-2017, 04:26 PM   #4
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
I agree with laynlo, getting wider wheels with the correct offset is the way to go.
With that being said, if you have to use them I'll give you my opinion on them since I have used them for over 7 years on my other cars as well. If you are going to use them, then do the following and you'll be fine.
- Always try get them from a reputable company like Eibach and H&R's. Those companies have been using spacers for off roading and such for years. Not sure about Ebay brands, just risky to me
- Always torque them down to spec! Torquing it tighter is actually more riskier so nothing over 140 ft lb (torque spec for the SS)
- Always make sure they're hubcentric IE Eibach/H&R's make it model specific for our cars that fits flush on our bore/hub
If you do those steps correctly, the spacer and wheel assembly will work well as whole unit and you won't have issues. I have them for over a year now, went over 125 mph w/out a single issue or vibrations. Then again, I have high quality spacers from Eibach and installed them correctly.
Richard0nee is offline   Reply With Quote
Old 03-11-2017, 04:34 PM   #5
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
Only reason I have looked at these is from the post
http://www.camaro6.com/forums/showthread.php?t=449883
Honestly the reason I am going for spacers is because I like the GM 5 Split spoke wheels I have but wish they sat flush with the edge of the wheel well.
Open to suggested high quality brand spacers, please link! I don't want to replace my wheels or buy wider ones and increase my yearly maintenance cost
GAHDOOSH
Old 03-11-2017, 06:36 PM   #6
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
I've run a 1/4 spacer in the past with no problems. I probably wouldn't go wider than that unless it's a hubcentric spacer. I ran a 1" hubcentric spacers on my old '03 Cobra (460rwhp) for years with zero issues, including racing it in the 1/4.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 03-11-2017, 07:47 PM   #7
horizon670
horizon670's Avatar
Drives: 2010 Chevy Camaro 2LT / RS / Auto
I've also used the Eibach hubcentric spacers: 15mm in Front and 20mm in Rear. They were very good quality... Very important to torque to the specific specs..
Just so you know, if you plan on installing your Split spoke wheels with any spacers that are smaller than 25mm, you will need to cut some of the original studs a bit. They dont have deeper pockets as other aftermarket wheels have.
horizon670 is offline   Reply With Quote
Old 03-11-2017, 09:07 PM   #8
Richard0nee
Correct, if you have the splits 5 and if you are going 20mms or bigger you will have trim the nubs of your studs.
I have the ones below from Eibach.. I'll pat the extra $ for a piece of mind and knowing I have a quality product.
https://www.facebook.com/photo.php?f...type=3&theater
