07-07-2021, 07:27 PM | #519 |
Drives: Black 2017 Camaro 2SS Join Date: Apr 2014
California_Blaqcar and USS Theodore Roosevelt
***FOLLOW UP*** I have been asked in the past about how I'm running the deep concave Ferrada Wheels. The 20x11.5 Ferrada's have a very aggressive offset. You can go back a few pages to see the posts and responses. Here is an update. I switched to Nitto Invo tires about two months ago. F - 285/30/20 R - 305/25/20 Absolutely no rubbing at any time. Even with three people in the car. There is more wheel well gap in the rear but I no longer have to be mindful of my speed in heavily bumpy areas. Also, the Nitto Invo's are better tires than the Goodyear Eagle F3's. More grip and noticeably more nimble. But they cost more as well. The issue with the rubbing with the Goodyears is how wide the sidewall is. It hangs slightly over the rim. Any 305/30/20 with a sidewall "thinner" than the Goodyears should work on the Ferrada rims with very little rubbing if any at all, even with a dropped suspension. Last edited by Cool SS; 07-08-2021 at 10:22 AM. |
07-23-2021, 09:10 AM | #520 |
2016 2SS Cabrio Manual
Drives: Camaro 2ss manual 2016 convertible Join Date: Jun 2021
08-17-2021, 01:02 PM | #521 |
Drives: 2018 Camaro 2.0T Join Date: Aug 2021
Hey guys new to the forum.
Any ways I have a 2.0t due to a 60 mile round trip. Its not the SS but i love my car. I also dont know how to rotate the pic lol |
08-23-2021, 05:17 PM | #522 |
Drives: 2018 Camaro 1SS Redline Join Date: Aug 2021
Have only had her about a month, and by far the best driving car I've owned.
2018 1SS Redline |
08-24-2021, 08:23 AM | #523 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
what wheel are those?
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
08-28-2021, 07:39 PM | #524 |
Drives: 2023 ZL1 1LE Join Date: May 2018
My understanding is that a Camaro SS or even an LT1 has the same sized rear wheel well as a ZL1 1LE, and that car runs 12" wheels in the back. I understand moving the wiring harness on the SS cars, is there any other reason nobody runs a 12" wheel with a 325 in the back on the SS cars? Seems like it could be done fairly easy if you don't mind a little poke like a factory ZL1 1LE (assuming the same offset is factory)? I'm picking up a new LT1 on Tuesday and want to do some stance wheels , 20x12 with a 335/30/ Michelin pilot super sport running negative camber.
08-28-2021, 09:23 PM | #525 | |
335/30 on a 20x12 wheel will be 1" taller and very wide, that one I haven't tried, but I run 315/30s on a 20x11 wheel and it's not exactly a spacious fit, a 335 on a 20x12 wheel will probably be a crapshoot in terms of fitment (without spacers, that is).
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 08-28-2021 at 09:41 PM. |
08-31-2021, 04:00 PM | #526 | |
Ive seen a couple of guys on here run this exact tire on a factory 20x11 SS Wheel and not have any issues (Although this tires minimum spec is a 11.5" wide wheel), so I could also get some 20x11 stance wheels in the SS 1LE offset and cram them on their. I may try the 12" wide wheel and test my hypothesis out!
2023 BMW X4M Competition (Downpipes, Midpipes, Intake, Exhaust, Tune)
2023 ZL1 1LE 19" BC Forged RS45- 325/345 Toyo R888R, KPMF Satin Pearl Wrap, GT Huas Exhaust. Incoming- Girodisc- Heads/Cam |
09-05-2021, 02:57 PM | #527 |
Drives: 2018 ZLE Join Date: Sep 2019
Waiting to get out on track.
09-06-2021, 08:59 PM | #528 |
Drives: 18' 2SS M6 Triple Black Join Date: Mar 2018
hey fam, sorry i haven't posted in a hot min. here are some recent photos of the car.
-HULK |
09-08-2021, 07:49 PM | #529 |
9six9 wheels in carbon grey i went with 19x10 285/35/19 with 5mm spacers all around front is perfect. Back needs a little push out but i noticed you have to cut the oem studs to put anything over 10mm spacer because the stock studs poke out in a spikish way. Not even the hole on the back of the rim clears it. Im just too lazy to take out my grinder.
09-13-2021, 10:38 AM | #530 |
I completely hear you about taking out the grinder. I finally caved since I really wanted a better look and can't afford new wheels/tires right now. I put 25mm (1") spacers on all fours with my stock 1LT 18" wheels. In my opinion, the stance looks way better now. Amazing what 1" will do (there's a joke in there somewhere...).
First car pic below is the before stock setup. Last edited by KKamaro; 09-13-2021 at 11:04 AM. Reason: pics |
09-20-2021, 06:24 AM | #531 |
Drives: 2023 Camaro ZL1 1LE Join Date: Aug 2021
My 2021 SS 1LE getting paint corrected and PPF.
09-20-2021, 12:22 PM | #532 |
Drives: 2017 2SS Arctic blue fully loaded Join Date: Mar 2021
wow
Tags |
truesoul313 |
