10-30-2017, 09:04 AM | #1 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
e85 AFR
Just curious what AFR your tuners are trying to get on these Direct Injected motors while running e85 type gas? 12.9?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
10-30-2017, 10:53 AM | #2 |
Bupp Motorsports
Drives: 2017 Summit White ZL1 A10 Join Date: Jun 2013
10-31-2017, 12:07 PM | #3 |
Drives: 2017 HBM ZL1 M6 Join Date: Jul 2017
Is it realistic to think these cars can do E85 without a cam with a higher flowing fuel lobe?
10-31-2017, 04:12 PM | #4 |
Drives: Camaro Join Date: Mar 2017
I usually shoot for around a 12.0-12.2 on a standard gas scale. Ethanol based fuels like to run a bit richer seeing as how oxygen is ~30% of it's makeup, so let it eat.
19 ZR1 | 16 Viper GT | 09 Z06 | 94 LS1 GT | 16 Denali | 19 CTS
http://www.gonicd.com |
10-31-2017, 04:22 PM | #5 |
Even on DI motors? I was led to believe they like it leaner.
11-01-2017, 12:06 PM | #6 |
Bupp Motorsports
11-01-2017, 01:52 PM | #7 |
They do, if it wasn't a DI motor I would be running low 11s on ethanol. Leaning out ethanol is unnecessary and you can actually give up some power and torque by doing that. Remember E85 is ~30% oxygen and getting more in the chamber will not hurt power at all.
11-01-2017, 02:21 PM | #8 |
Do u follow the same rule if NA vs Supercharged?
11-01-2017, 04:22 PM | #9 |
Generally speaking yes same rule but obviously not the same numbers.
