11-19-2019, 08:18 PM | #1 |
Drives: 2018 A8 Camaro SS Vert Join Date: May 2019
To FI or not.....
I am really struggling with deciding what route I want to go as far as adding more power. I have no plans to hit the track and it is kind of my daily driver (I divide it with driving my Jeep JK). Not looking to get above 600-650 hp and not looking to hit 9's on the track. So basically I am looking for bragging rights and streetability. Should I go supercharger or should I stick with NA and build up the engine with a cam and headers and intake and TB? They both seem to be the same price range (8-10k)
Thanks for any advice. |
11-19-2019, 08:41 PM | #2 |
2018 605 RWHP 6 speed 1SS
Drives: 2018 Camaro 1SS Join Date: Apr 2019
Selling my procharger set up for 4.5k that has my car at 605rwhp.
11-19-2019, 08:48 PM | #3 |
For street use, the torque of a PD blower is tough to beat IMO.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15 conversion 1059 WHP/944 WTQ, 9.48@150
11-19-2019, 10:30 PM | #4 | |
Drives: 2017 Camaro ZL1 Join Date: Sep 2019
Reason for asking, if you have the A8, I would go NA. I had a 2016 that I Magnuson SC, and never could get it right ( transmission shifting in other than WOT ). Plus that cam sound is hard to beat.
2017 ZL1 White A10 ... Vengeance Racing - custom camshaft, CNC aluminum ported heads, engine internal upgrades, SC pulleys, Rotofab CAI, ported TB, Kooks headers, Corsa Sport exhaust cat back with black tips, Incurve Custom Wheels. |
11-20-2019, 07:27 AM | #5 | |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Once you exceed a certain power level you almost need to run Drag radials or a drag pack on your car daily. lol It's like a hellcat with 707 HP on 245 width street tires. Some of the guys who go after huge power here are track enthusiast who have the proper setup to put that kind of power down on a properly prepped track. Just some things to consider.
11-20-2019, 08:48 AM | #6 | |
11-20-2019, 09:03 AM | #7 |
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8 Join Date: Dec 2018
Following.
Great question and great feedback - thanks guys. |
11-20-2019, 09:04 AM | #8 |
I have pulled 6.x 0-100 with my Whipple on the street. The torque and power across the entire curve is addicting. Traction is all based on setup and driver...not the type of power adder.
That being said a Centri setup is very capable but needs a higher stall converter(3600) to optimize it's potential on a A8 car. So my recommendation would be if you do not plan on changing converter is to get a Maggie or Whipple because they work well with the stock stall speed. If converter swap is in the cards then a P1x setup would rank right up there. These cars fly NA with a good heads/cam package as well but also needs a stall converter(4000)...so if you want stealth, go FI...if you want to shake rattle and roll, then stay NA. It's Not real difficult to make power and go fast in 2019.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 11-20-2019 at 09:18 AM. |
11-20-2019, 09:06 AM | #9 |
Drives: 2016 Camaro SS Join Date: Sep 2018
I've been modding cars for a long time and have had everything from big NA builds to nitrous builds to turbo builds. With that being said after having a boosted car I will never build another NA car, after feeling something with a turbo or supercharger NA and nitrous builds just don't do it for me anymore.
11-20-2019, 09:21 AM | #10 | |
The only thing I haven't had is a turbo build. And had that Huron speed kit been available prior to my Whipple purchase, I likely would of given it a shot. I really like the looks of that setup. Be a killer setup with a nice Circle D 32-3400 stall converter.
2016 NFG 1SS A8
11-20-2019, 09:34 AM | #11 |
Drives: Chevy Camaro Join Date: Jul 2019
So the Procharger benefits from a higher stall, I am contemplating a power adder but I don't really want to change the TC, they just seem so much easier to install.
11-20-2019, 10:06 AM | #12 |
Oh yea huge difference just ask Brett @ Prayperfomance.
2016 NFG 1SS A8
11-20-2019, 10:36 AM | #13 | |
These are all great points. The main thing is I want to feel like I have added power even when just passing someone in the slow lane. I don't want to have to take the car up to 5000+ RPM just to get the power to kick in. |
11-20-2019, 12:47 PM | #14 |
Then you want a PD blower.
