Old 08-12-2019, 06:28 AM   #1
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
is this normal?
Hi, about a year ago I installed a flowmaster cat back exhaust. Now has an exhaust leak stain at the connection -see photo-
1. Will this eventually corrode into a hole on the GM cat side pipes?
2. Can I assume they are stainless?
3. In the photo, the left side is the engine side, the right side is the flowmaster exhaust side. Does Anyone know why all the staining is so prominent only on the left side of the connection clamp?
2016 SS M6
MR-02 is offline   Reply With Quote
Old 08-12-2019, 12:58 PM   #2
VinnAY
Drives: 18 1SS/1LE
Im unconcerned by it but I would get under there and see if you can get another turn on those nuts.
Old 08-12-2019, 08:38 PM   #3
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
Hi and Thanks,
...but is the GM pipe stainless? Will it rust out if it gets worse?
2016 SS M6
Old 08-12-2019, 09:51 PM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
1. no
2. yes
3. don’t know. maybe gravity. The black wet soot often drips out of the stock suitcase’s weep holes. It’s just soot.
Old 08-13-2019, 02:33 PM   #5
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
1. no
2. yes
Ok Thanks!
2016 SS M6
