08-03-2019, 09:04 AM | #1 |
Drives: 2016 2SS Join Date: Mar 2019
Help with Bose and aftermarket
I am a second owner of 2016 2SS. Had a car for few months, sound system sounds like crap. I mean really bad, objectively. The car originally came with Bose system, there is some aftermarket equipment installed. Need some help sorting things out.
From what I could gather, there are six speakers in the car. Front tweeters, front door speakers, rear speakers. All speakers except for the rear look to be OEM. the rears were changed to Morel Tempo Integra 140W 6”x9” speakers. The original Bose amplifier is still in the car mounted above left rear tire. There is also Fix 82 DSP and JL Audio HD 600/4 Amplifier. Four input channels of Fix 82 are utilized, channels 1, 2, 3, and 4. I haven’t traced inputs but they are coming from the original harness that was modified. Analog output from Fix 82 is routed to the amplifier and connected to front left and right channel input. Front speaker out is connected to tweeters and door mounted speakers (unplugged n the pic as I was trying to figure out connection). Rear speakers out is connected to the rear speakers. I could see mounting holes from the subwoofer but it is gone. So few questions.
08-03-2019, 10:27 AM | #2 | |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
Are the door speakers supposed to be used as subwoofers / base in the OEM setup? Yes, in the Bose system, the door speakers are being sent frequencies in the midbass /subbass range. So from about 500Hz down. But the signal you are getting is more of a full range due to the Fix82 I understand that Fix 82 is used to mix all channels back together so the original signal could be used to drive the amp. But there are so many settings. And I don’t even know what each input was originally used for. Any recommendations on what to do here? First thing you need to do is get this. https://catalog.pac-audio.com/catalo...faces/ap4-gm61 or this https://navtv.com/products/NTV-KIT838/m650-gm.html This should be connected and then run to a DSP such as a Fix82 , Hertz H8, Audison bitone. Or, if you want to forego advanced tuning, you can run this unit straight to an amplifier or two. There is no analog full range signal leaving a traditional headunit. So the person that set your vehicle up is attempting to sum signals from the OEm amplifier that are EQ'd, time delayed, AND not full range. This is not ideal Originally front tweeters and door speakers were on separate channels, now they are combined on the single amplifier output. How do I deal with this? I am not sure if he has a passive amplifier in there somewhere separating the signals. This can be stand alone, or can sometimes be done at the level of the midbass driver, depending on the setup. If you plan to run a 2 way front stage with tweeter and midbass/midrange, most of those will come with a passive crossover. This way, you can send one full range signal to the crossover, and it will separate the frequencies for you. Should I just leave the current setup and add subwoofer that is clearly missing from the system? In short... HELL NO! Hope this helps
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
08-03-2019, 10:49 AM | #3 |
@drfeelgood,
Thank you for the reply. I will look into your suggestions and circle back with more questions I am sure. I am the type a guy who prefers to do his homework before I start cutting wires. Electrical engineer by trade so hopefully I could figure this out, bit over my head for now. Appreciate your help! |
08-03-2019, 12:12 PM | #4 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
https://www.camaro6.com/forums/showthread.php?t=558538 https://www.camaro6.com/forums/showthread.php?t=547568
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
08-03-2019, 07:37 PM | #5 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2011
That does not look good....
08-03-2019, 08:46 PM | #6 |
Ugly install but he has good pieces to work with. Just needs a Bose signal processor and some pretty wiring ends.
08-04-2019, 09:01 AM | #7 |
Few questions from a guy who replaced a stock radio in the car about 300 years ago
PAC connects to the radio in the dash. The function of the radio unit in the dash is to drive the display and to provide audio source such as radio, blue tooth, etc to the Bose amp in the back? Are these four channels currently plugged into my Fix82. What is the reason it is broken up in so many channels BEFORE it gets to the Bose amp? If I install PAC, why do I need Fix82? It seem to me I will have to run wires from the PAC to the back of the car so I could install amps (or use the aftermarket one that is already there) and connect speakers that are all wired to the back? thanks everyone |
08-04-2019, 10:05 AM | #8 | |
The Fix82 is a digital sound processor. It will allow you to fix the time delay from the stereo so that the sound waves from the door speakers reaches your ears at same time as the back Speakers.
08-06-2019, 06:58 AM | #9 |
Hit a snag last night, went from crappy sound to no sound at all. Need some help please. Also, correction to my previus post, I have inputs 1,2,3,4,7,8 utilized on FiX 82.
Wanted to use TuN software to see settings a previous owner used in Fix 82. First was unable to connect my laptop, had to update Fix 82 to the latest firmware. No issues there, went smooth. The next step was to go through the calibration status. Tried using the software, no luck. All i get is "failure: low input signal level". Tried disabling some of the inputs prior to calibration as was suggested in one of the videos, same thing. Also tried to do it by just pressing the button on the module itself, indicator LEDs for the input status stay solid red, calibration status LEDs blink four times which according to the manual means no/low input signal level. I am dumbfounded since I didn't change anything other than a firmware upgrade. Manual talks about some of the OEM needing FiX-LSA-4 to activate OEM amplifier outputs, but if it was working properly before I don't think I need it. Could someone please through some suggestions at me on what t do next. I am at a loss. |
08-06-2019, 01:55 PM | #10 | |
See if this helps: https://www.crutchfield.com/S-pfQV30...FiX-LSA-4.html
08-06-2019, 02:03 PM | #11 |
@KirkH, Thank you for the reply. FiX-LSA-4 is designed to present an appropriate impedance load to OEM head unit or amplifier outputs that employ ''load-sensing startup protection". Since it was properly working before, I don't think this is an issue.
08-06-2019, 02:51 PM | #12 | |
The link description of the LSA 4 says: "Some factory radios and amplifiers will not work without sensing that its speakers (low-impedance loads) are connected to their outputs. So adding a sound processor that uses the factory wiring for its inputs, like a JL Audio FiX 82 or FiX 86, would normally result in no audio at all." That sounds like what is going on with your system. Perhaps the previous user had hacked the firmware or something, and when you updated the firmware, you get the "normal" response of "no audio at all".
08-06-2019, 06:21 PM | #13 |
So to be 100% frank, you don't really need the fix 82. as mentioned, a full DSP also has time alignment and a full 32 band EQ for each channel. That allows for pretty precise tuning within the car.
If you don't want that level of tuning and speaker attenuation, you can just bypass the fix82, and install the pac unit. You wont have to worry about all of those speaker wires going to the Fix 88, as the Pac unit will link directly with the headunit, and you can run low level (RCA) output, high level output, or Toslink directly to your amplifiers (if you have digital amplifiers that accept optical input)
08-06-2019, 07:02 PM | #14 |
Very good and important point!
