07-03-2019, 10:38 AM | #1 |
@texan.1le
Drives: '18 Camaro 1SS 1LE, PDR Join Date: Jun 2018
Oil Fill funnel for LT1, L86/3 and/or EcoTec Engines
When I had my 1LE at the dealer for its second free oil change, I noticed the tech that was performing the work had a particular funnel that screwed in place where the fill cap goes. I believe it had a bit of an angle to it to. He was able to screw the funnel in in place of the oil cap, start pouring in a bottle of M1 0w-40, and let the bottle sit in the funnel to finish draining. No mess, no fuss, and it worked like a charm. I didn't get the chance to ask him where he got the funnel. He appeared to be the only one using it at the time.
Does anyone know about this style of funnel or where I could pick one up? The ones I see online (like at Amazon) usually state that they dont fit the 5.3 Ecotec V8's (L83), which I would assume have the same oil fill caps & threads as the L86's and LT1's. If one that works for our LT1's would also work for the 2.5L N/A Ecotec or the 1.4L Turbo Ecotec (Trax), that would be a bonus too. Any ideas?
'18 1SS 1LE - "Mongoose"
'15 Malibu 2LT - daily |
07-03-2019, 10:39 AM | #2 |
never seen anything like that before
07-06-2019, 01:35 AM | #3 |
Thanks for sharing. Is this what you saw the tech using?
https://www.amazon.com/OEMTOOLS-8702.../dp/B0771KVLF3
07-06-2019, 04:41 AM | #4 |
Thank you Al Oppenheiser!
I use the top of a 2 liter bottle and then put a standard aluminum funnel nested inside it. The 2l stays put and holds the metal funnel at just the right angle.
Works perfectly. |
07-06-2019, 07:09 AM | #5 | |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
07-06-2019, 12:35 PM | #6 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
07-08-2019, 07:22 AM | #7 | |
@texan.1le
I re-read all of the reviews of these and decided to try this one anyway. The MotivX people say they are working on an adapter to fix the angle issues on the 5.3 and 6.2 V8's. I ordered it this weekend and it should be here today. I'll try to snap a pic or two of it on my car this evening to see if 1. it fits, and 2. how bad the angle is. https://www.amazon.com/Motivx-Tools-...YEKDMBA8M2MFQY
07-09-2019, 04:01 PM | #8 |
Yes, there’s a bit of an angle issue... I slide different oil fill funnel inside and that modifies the angle for a smooth pour.
07-09-2019, 04:25 PM | #9 |
Kevin
Drives: 2018 Callaway Camaro ZL1 1LE Join Date: Apr 2018
Mine is the same but the top is blue. Works great. Little bit of an angle issue with the 5qt jugs but you can pour the oil in pretty quickly.
07-11-2019, 11:49 PM | #10 | |
Drives: 2019 Camaro 2SS A10 Join Date: Feb 2019
2019 2SS: A10, Satin Steel Gray Metallic, MRC, Nav.
07-14-2019, 08:36 AM | #11 |
Drives: 17 Camaro 2SS 50th Anniversary Conv Join Date: May 2017
I have used this before works great. Lisle makes other ones also.
https://www.amazon.com/Lisle-19342-M...ateway&sr=8-48
2017 2SS 50th Anniversary Convertible,A8,MRC,NPP,NAV,Black Bowties
07-20-2019, 09:00 AM | #12 |
07-24-2019, 10:54 AM | #13 |
Drives: 2019 Camaro SS 1LE Join Date: Jun 2019
Some people must have a lot of disposable income, congratulations and God bless you all.
Personally I’ve been using the same $.99 automatic transmission funnel for the past 40 years and I’m happy with it. |
