@4secnds6gen
Drives: 16 Camaro 2SS A8 Join Date: May 2017
Driving Mode Missing?
Has anyone had issues where the driving mode randomly disappears?
Kooks 1-7/8 Headers-Catless Tony Mamo Ported 87MM TB Ported LT2 Intake Manifold/ Flex Fuel MRT 3in H-Pipe w/No Mufflers RotoFab Dry CAI Mishimoto Catch Can Mustang Dyno w/ WCF 480RWHP /490TQ E70 Instagram Here YouTube Here ---------------------------------------------------------------- |
![]() Drives: 2106 SS Join Date: Aug 2016
Worse. The whole thing went blank
![]() Sent from my SM-G935V using Tapatalk |
@4secnds6gen
Damn. Yeah your is a big deal. I guess I'll shut the hell up then.Lol I wonder if it was an OTA update or something which causing the issue
Lol. I heard they at least knew about it
![]() Drives: 2020 1SS 1LE Join Date: Dec 2016
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
If your screen is blank/black its an easy fix. My car has done this to me once. Its in the fusebox in the trunk. Position is "F16 DISPLAY" pull the fuse wait 10 seconds and plug it back in and you should be good. Avoids a trip to the dealer but there is an update thru GM that eliminates this software issue. I just cant be bothered going in for this as I sais it happened about a year ago.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
#7 |
Summit White 2SS
Drives: 2017 Summit White 2SS, 2018 Tahoe Join Date: Nov 2016
There are several posts for this issue. Check out
http://www.camaro6.com/forums/showthread.php?t=472478 http://www.camaro6.com/forums/showthread.php?t=437558
____________________ 2017 Summit White 2SS |
#8 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
You need to learn to use the search option before posting. There are already several threads regarding this issue.
![]() See post above for links. Repeat threads should be locked.
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD |
Thread Tools | |
