06-01-2011, 03:43 PM | #15 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
I just want them to replace it with a good one.
06-01-2011, 06:30 PM | #16 | |
Drives: 2010 Camaro 2SS Join Date: Mar 2009
FOR SALE:
- Maggie w/ 3.6" Pulley | Kooks Coated 1 7/8" LT Headers | Rotofab CAI | MSD FPVB | ZR1 Twin Disc Clutch / LPE flywheel | MGW Short Throw Shifter | Diablosport Trinity / PLX boost & AFR sensor modules | TCI line-lock |
06-01-2011, 11:19 PM | #17 | |
It is likely that the shaft is made of AISI 8620 alloy, but was not carburized properly. AISI 8620 should have a carbon content between 0.180 - 0.230 %. The carbon content of the defective shaft averaged 0.27%. Higher carbon makes the material harder and also more brittle. There are also signs of quench cracks and inclusions in my sample. Not going to get technical here (unless there are people who actually care). So, what does it all mean, man!?! My professional opinion: The root cause of the shaft failure was improper heat treatment. These defective shafts came from the factory with VERY small cracks and other internal defects. The cracks grow over time. How fast depends on the loading placed on them. The crack will eventually reach a critical length and the shaft will snap like a piece of chalk.
FOR SALE:
06-02-2011, 07:53 AM | #18 |
Drives: 67 goat, 69 goat ram air III Join Date: Mar 2009
As an old 'heat-treater' of ferrous and non-ferrous metals, I would be interested in the process they used. They must be quenching in some warm media. Surely it is not design. Possible stress from machining that was not handled in the heat treatment?
06-02-2011, 09:03 PM | #19 | |
The next test in the failure analysis is EBSD to map the grain structure. The machine is already booked by 'paying' customers, so it may be a week or two before they get this test done, but it should provide more insight.
FOR SALE:
06-02-2011, 09:27 PM | #20 |
Drives: 2011 2SS/RS Summit White :) Join Date: Oct 2010
This is a great investigation, interesting on the carbon content.
06-02-2011, 10:34 PM | #21 |
If my trans hasn't been sent back yet, I'll snap a pic of it tomorrow.
06-02-2011, 11:39 PM | #22 |
as for the poster above that is talking about footing the bill... i payed 5k for a trans from keisler when mine happened. My warranty was voided and I didn't have a transmission for 7months... Thats what happens when your in the first group of breaks.
85 Buick TType - 5.3l GT4202r 10.86 at 126
06-02-2011, 11:42 PM | #23 |
That really sucks....however the plus side is you no longer have to worry about your trans.
06-03-2011, 12:02 AM | #24 |
In The Circle
Had Pumpkin up on hoist yesterday, when I rolled the the rear wheels foward and backward a very noticable clunk was coming from the tranny. Any ideas?
06-03-2011, 08:23 AM | #25 | |
06-03-2011, 09:43 AM | #26 |
Hmmm... Need more info. Your car does run, right? Was it in neutral? Could you tell if the clunk was coming from the tail end or was it inside the trans?
FOR SALE:
06-03-2011, 09:46 AM | #27 |
It would be very helpful and greatly appreciated!
FOR SALE:
06-03-2011, 09:48 AM | #28 |
I'll scan and post some relevant info from the ASM Heat Treating Handbook later today.
FOR SALE:
- Maggie w/ 3.6" Pulley | Kooks Coated 1 7/8" LT Headers | Rotofab CAI | MSD FPVB | ZR1 Twin Disc Clutch / LPE flywheel | MGW Short Throw Shifter | Diablosport Trinity / PLX boost & AFR sensor modules | TCI line-lock Last edited by mwt18; 06-03-2011 at 01:38 PM. |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
What do all the abbreviations mean? | CrzyGamr2 | 5th Gen Camaro SS LS LT General Discussions | 77 | 12-07-2012 04:34 AM |
Camaro Control Arm failure analysis and solution | PfadtRacing | Suspension / Brakes / Chassis | 114 | 07-21-2011 02:38 PM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
DriveshaftShop is now testing a new 31 spline Tran. output shaft | Driveshaftshop | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 24 | 12-24-2010 04:27 PM |
