02-10-2011, 05:21 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Mar 2009
Built in Dyno ???
I was playing around with my Diablosport Trinity today and found a parameter called "Engine Actual Steady State Torque". I turned it on and it seems like a pretty accurate measurement of the engine torque output. I also logged a WOT run in 2nd gear and plotted it against RPM. The trend of the curve follows my real dyno curve really closely. It is about 15% higher, though.
Does anyone know how the ECU measures/calculates the "Engine Actual Steady State Torque" and how accurate it really is? Here's a couple of pics. 1. A pic of the gauge (at idle). 2. Plot of Torque vs. RPM.
FOR SALE:
- Maggie w/ 3.6" Pulley | Kooks Coated 1 7/8" LT Headers | Rotofab CAI | MSD FPVB | ZR1 Twin Disc Clutch / LPE flywheel | MGW Short Throw Shifter | Diablosport Trinity / PLX boost & AFR sensor modules | TCI line-lock |
02-10-2011, 06:52 PM | #2 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
I've set up my HP Tuners to have a PID for delivered torque. Its not accurate, but its a good gauge. Its consistant, but not accurate. I use it as a gauge to see it I picked up torque when adding fuel or timing, or if it drops off. Its a good instrument, but not true. Im not sure if yours is the same
02-10-2011, 07:52 PM | #3 | |
Sure wish Ted Jannetty would chime in.
FOR SALE:
- Maggie w/ 3.6" Pulley | Kooks Coated 1 7/8" LT Headers | Rotofab CAI | MSD FPVB | ZR1 Twin Disc Clutch / LPE flywheel | MGW Short Throw Shifter | Diablosport Trinity / PLX boost & AFR sensor modules | TCI line-lock Last edited by mwt18; 02-10-2011 at 07:58 PM. Reason: typo |
02-11-2011, 07:48 AM | #4 | |
I can make it read very high or very low and not change the power output. A Dyno is Still the Best way to Accurately see if you gained or lost when making changes because it is independent of the car. Ted.
www.jannettyracing.com
02-11-2011, 08:42 AM | #5 | |
Do you know how the ECU measures this output? Can you say more about what tuning procedures affects it's value? Thanks
FOR SALE:
02-11-2011, 09:53 AM | #6 |
All I can say is it is Calculated based on multiple Sensors
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
AIRAID Dyno Test & Videos For 3.6L Camaro | Airaid Filters | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 543 | 05-26-2010 10:46 PM |
MTI Racing Hosting Dyno Day | MTI Racing Kevin | USA - Southeast | 9 | 04-03-2010 06:00 PM |
DYNO, INSTALL, DYNO, TUNE, DYNO | JANNETTYRACING | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 11-17-2009 05:11 PM |
Pick Your Song for Delivery Day | joepitt | 5th Gen Camaro SS LS LT General Discussions | 179 | 09-22-2009 07:39 PM |
