02-17-2022, 05:55 PM | #1 | |
NATURAL NITROUS ???
i just ran across this stuff its pretty interesting...not sure if i believe it or not but
04-01-2023, 09:59 PM | #2 |
Drives: 2016 Camaro Join Date: Oct 2017
Cool dense air makes power.
Dodge uses air conditioning diversion on their high-performance Demon supercharger systems to make incoming air cooler. There are other aftermarket systems that do the same thing. That is, to cool the incoming air. Performance gains are good. Check out: https://fiinterchillers.com You can reduce intake temperatures like 30-degrees. Envision the intercooler lines going into your supercharger frost covered.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
Thread Tools | |
