09-21-2021, 09:53 AM | #1 |
Drives: 2012 Camaro SS Join Date: Aug 2021
Trunk light fuse
I was changing the bulb in the trunk light. Unfortunately, I have fat fingers so I was using a small flat blade screwdriver to pop it out. I mistakenly touch the socket and some of the surrounding metal and it sparked. Now the light doesn't work. Where is the fuse for this light? Thanks for your help. I appreciate it.
Mike |
09-21-2021, 10:21 AM | #2 |
Drives: 2012 Camaro 2SS/RS Vert LS3/M6 Join Date: Aug 2021
Service Manual indicates Rear Compartment Courtesy Lamp (E8S), circuit 737 feeds from 15A Fuse F23 (BCM#4) in the Instrument Panel Fuse Block
09-21-2021, 10:24 AM | #3 |
fuse panel
