Old 09-22-2017, 04:08 PM   #1
Urbanizer
Drives: 2010 SS
Does F/R rotor diameter really matter?
I recently had to replace my rotors and pads on my '10 SS and upgraded to a drilled and slotted rotors. I had them installed at a local brake shop, but didn't really specify where to install the larger diameter rotors. Since most cars have the larger ones up front that's how mine got installed.
What are the disadvantages I could experience if I kept them this way? Is it worth getting them swapped to match the OEM setup?
Urbanizer is offline   Reply With Quote
Old 09-22-2017, 05:33 PM   #2
Synner
Drives: cars
Disadvantages of having them installed correctly with larger rotor up front? That would be none.
Synner is offline   Reply With Quote
Old 09-22-2017, 06:12 PM   #3
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
I have never heard of having larger rotors on the rear, the front does the majority of the braking.
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 09-22-2017, 06:48 PM   #4
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Well considering that you can't put the rotors from the rear of the car on the front I think you'll be fine.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 09-23-2017, 08:04 AM   #5
ChasperL99
ChasperL99's Avatar
Drives: SW 2010 2SS RS
Front rotor 355.2mm, rear 365mm. Rear is larger. However, like someone said, rear, has the e brake.
ChasperL99 is offline   Reply With Quote
Old 09-23-2017, 09:37 AM   #6
Synner
Drives: cars
Weird, had ZL1 brakes too long. The rear pad and caliper is still much smaller. The parking brake takes up the extra space. It's not physically possible to reverse the install.
Old 09-25-2017, 09:52 AM   #7
Urbanizer
Drives: 2010 SS
Yea currently I have 365mm in the front and 355.2mm in the rear. I'm not sure if there pads/break pistons will be effected by this.
Additionally if the parking break is in the rear I don't want anything slipping because of a smaller than stock rotor there.
Old 09-25-2017, 02:57 PM   #8
1Coopgt
1Coopgt's Avatar
That's not possible either . Your e-brake is a drum brake on a car from the 60's only simpler. If your e-brake slips it because it's not adjusted correctly or you didn't pull it up far enough.
Old 09-25-2017, 03:28 PM   #9
Urbanizer
Drives: 2010 SS
I wasn't aware of that, thanks for the clarification!
brakes & rotors, diameter
