07-14-2019, 09:45 PM | #1 |
Drives: 2018 Hyper Blue Camaro 1SS 1LE Join Date: Feb 2019
ZL1 1LE replica spoiler flexing
So I have a ZL1 1LE style spoiler on my SS 1LE from Extreme Online Store that I got about a month ago and have a couple questions. Does anybody know if it's normal for the ends of the spoiler to bounce or flex at higher speeds? And if so, is there any way to stop it from happening or am I SOL?
I can be going 70 on the highway and see the end and winglet bounce up and down in the wind. I'd like to avoid selling it and getting a new one, so if anyone has any idea if it's a normal thing for a spoiler like that to flex at higher speeds then it's no big deal, but if not, I am open to ideas for fixing it. Also please don't shame me for going with a cheaper spoiler because I mostly did it for looks Any help would be much appreciated! |
07-14-2019, 10:56 PM | #2 |
Theoren Hanks
With these molded ABS splitters you will have this issue sadly. Only way to fix it would be to add some structural material underneath it to stiffen it up and find a better way to mount it to the bumper
07-14-2019, 11:34 PM | #3 |
Sorry, I should have clarified a little better that I was talking about the deck lid wing. But yeah I figured that’s how it was gonna be with abs parts. I’ve played around with the idea of skinning it in real carbon fiber or fiberglass, but the time and money that would be involved just wouldn’t be worth it. Also considered putting some kind of thin wood or metal bracket throughout the inside of the spoiler to stiffen it up but I’m worried that would be adding too much weight, and if I went with a material that wasn’t strong enough, it wouldn’t fix the problem.
I was hoping to see if it’s something people just knew about and lived with, or if they did something to fix it. It’s also weird to me that on all the posts about the abs plastic spoilers, no one ever mentions how they flex in the wind. |
07-15-2019, 11:38 AM | #4 |
I have seen a similar issue with mine i purchased as well for my 18 camaro, the zl1 1le highwing. The brackets themselves are very firm when i try to use force on them, the top spoiler material i believe is meant to flex in the wind, it can be nerve racking to see it flexing while driving at high speeds, i check it regularly after driving on the highway or at high speeds for long periods of time.
As long as it was installed properly i believe the wind would and your speed would have to be very strong for it to want to fly or break off, but the install user error could be a factor, but again my stands are very strong but the winglet areas can flex and shake some but i never notice the spoiler itself move, just the corners that stick out. You SHOULD be OK, but i have that same fear sometimes driving at high speeds when its windy outside even without the speed of the car as a factor. Spending over $1,000 on this and painted for it to fly off would SUCK, it does make me nervous cause i was the one that installed it, and the only thing holding the spoiler to the brackets itself is plastic where the bolt screws into, i wish the material was metal or aluminum where they were actually mounted. |
07-15-2019, 01:18 PM | #5 |
if its a replica thats pretty normal...
07-16-2019, 02:47 PM | #6 |
Drives: Camaro Join Date: Aug 2013
Unless its a composite wing or GM wing, the plastic wings flex a lot and tend to vibrate / flap. Thats why we build ours in composites vs abs..
07-18-2019, 12:07 PM | #7 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
Run short screws in to in thru the oem spoiler holes.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
07-19-2019, 12:44 AM | #8 | |
IG: Infinite.Drive
Drives: 2016 Camaro 2SS in Summit White Join Date: Jul 2016
Replace with OEM or something made of strong composite like C7s replica parts and you'll be Gucci-gang
________
Fight your mind |
07-19-2019, 07:40 PM | #9 |
Thanks for all the response everyone! I assumed that was the case with abs versus composites.
07-19-2019, 08:34 PM | #10 |
Drives: 2019 SS 2019 mustang GT Join Date: Apr 2017
had a chance to see one of yours in person very impressive just can't decide if I want the gloss black or carbon fiber LOL
