06-23-2019, 06:06 AM | #1 |
Drives: Camaro ZL1 Join Date: Apr 2019
Helix sequential LED rear tails (amber) fitted
After some research I went with the Helix tails.
Easy to fit, all LED and they have a switch on the back to change from sequential to fixed flash on the indicator. (I need amber for the UK) The only addition was a Gen5DIY wiring harness that stops the camera being permanently on due to the current sensing draw from the reversing LEDs. Huge thanks to them for overnighting the cable, meaning the car could get sorted and on it's way to the Port to start it's 4500 mile journey! Video - please excuse the quality
Made in the USA. Refined in Great Britain - insta: zl1uk
Velossa intake, Rotofab, Mamo TB, Custom ported NX Lid & Jokerz Full tilt ported LT4 charger, 3 port CoolingMist Meth injection - ATI 15% lower pulley, E2X CC, TSP ceramic coated longtubes, de-cat and Borla 60608 to NPP box, JRE tune, BMR rear control & trailing arms, lock-out kit, lowering springs and front strut brace, Custom carbon trim interior, Xpel ultimate front PPF and Prestige window tint with Chameleon Windscreen tint...ever evolving... |
06-23-2019, 06:52 AM | #2 |
Drives: 2018 SS Join Date: Jun 2018
Do the blinkers come on at first when you hit the brakes?
06-23-2019, 07:10 AM | #3 |
No.
07-07-2019, 05:07 PM | #4 |
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
I need to know if your inside door lock lights still light up when you have it parked for lets say an hour or so, I had these on my 17 SS and for some reason, I was getting a power drain to where after 3 days parked I would have to jump it, normally your inside door lock lights are on when you are driving and should be off when parked, I switched back to my dark GM tails and my inside door lock lights are off now, please let me know if you have the same symptoms.
07-08-2019, 04:11 AM | #5 | |
07-09-2019, 03:17 AM | #6 | |
07-19-2019, 07:07 AM | #7 |
Thanks for the heads up, I will be getting the harness today but will decide if I want to leave the factory darks in or put the helix lights back on, time will tell.
07-23-2019, 02:40 AM | #8 | |
07-23-2019, 09:56 AM | #9 |
I did get the harness, it looks like the one that I got for my GM dark tail lights for the LED back up lights, I need to look to see if they are one and the same, if that was the case I could have used that one.
