03-24-2022, 06:04 PM | #1 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Mobil 1 0W 40 ESP is Rebranded Mobil 1 Supercar
I thought it was time for another oil thread.
Seriously, it was reported today on CorvetteBlogger that Mobil 1 0W 40 ESP is being rebranded Mobil 1 Supercar. This should eliminate any confusion with the 0W 40 European formula. This oil will be the factory fill for the Camaro ZL1 and C8 Stingray. A 5W 50 weight will be the factory fill in the LT6. https://www.corvetteblogger.com/2022...il-1-supercar/ Oh yea, instead of a Dexos2 designation it’s now the new DexosR.
03-24-2022, 06:16 PM | #2 |
Drives: 2022 ZL1 M6 & 2023 Stinger GT AWD Join Date: Nov 2021
Book calls for Dexos2 so DexosR will get us into trouble when something happens?
2023 Kia Stinger GT AWD - as a family car...
2022 ZL1, M6 as daddy's ass mover Charger sold! Better to sell, than waiting to be stolen... |
03-24-2022, 06:39 PM | #3 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
Thanks Hawk… I’m certain that GM will be sending out extensively detailed information with all the specifics…. Riiiiiiiiiiiiight!!!!
03-24-2022, 07:01 PM | #4 |
03-24-2022, 07:13 PM | #5 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
I guess this finally confirms the ZL1 is a super car!
03-24-2022, 08:15 PM | #6 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Meh, I'm switching to Driven oil in two weeks at my next oil change.
03-24-2022, 08:17 PM | #7 |
I’m running Driven here as well. Seems to be working out well.
03-24-2022, 08:52 PM | #8 |
Mobil 1 5W-30
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
03-24-2022, 09:17 PM | #9 |
I'm running Amsoil Signature
03-24-2022, 09:25 PM | #10 |
Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
From the article:
“Mobil 1 Rebrands ESP Formula 0W-40 as Mobil 1 Supercar” Also from the article: “Mobil 1 Supercar 0W-40 may share the same name as Mobil 1 0W-40 but these two blends aren’t the same and are not interchangeable. Mobil 1 says that while the viscosity is identical, the formulation of Mobil 1 Supercar 0W-40 is the result of 24 months of grueling tests and precise engineering, and it’s specifically designed to guarantee it meets the strict dexos-spec required for all C7 and C8 Corvettes.” Thank you CorvetteBlogger for the confusion Good that I checked, as I was planning to use my remaining ESP quarts with new Supercar quarts. But according to that last bit, this is not advised… Geoff |
03-24-2022, 11:00 PM | #11 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
I think you read that wrong. Mobil 1 ESP 0w-40 IS Mobil 1 Supercar. If you have ESP, you absolutely can use it with Supercar. It's the regular Mobil 1 0w-40 they want to avoid confusion with.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
03-24-2022, 11:11 PM | #12 |
2020 Shadow Gray 2SS
THIS... Mobil1 0W-40 ESP is the exact same oil as Mobil1 0W-40 SuperCar... Mobil1 says that themselves...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
03-24-2022, 11:16 PM | #13 |
03-24-2022, 11:24 PM | #14 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Interchangeable? IMO, I'll take that with a grain of salt from a blogger. If we actually look at the technical properties data, they are identical. They both are Dexos 2 certified, 0W40. Nothing bad will happen if they are mixed. If there was some sort of terrible chemistry as a result of mixing them, GM would have introduced a new certification.
>Marketing< And if we look at Mobil's display, it says: "New look, same tech" "The new advanced synthetic was originally called Mobil 1 ESP Formula 0W40............Now the name is changing..........." 0W40 ESP GL-XX-Mobil-1-ESP-Formula-0W-40.pdf 0W40 SuperCar Mobil has already certified the European ESP X3 0W40 as Dexos 2. 0W40 ESP X3 European GL-XX-Mobil-1-ESP-X3-0W-40.pdf Actually, the European X3 0W40 has little better viscosity #s
