11-13-2019, 04:25 PM | #1 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Borla 60626 install with factory exhaust.
For those of you that have installed the Borla 60626 onto your factory ZL1 exhaust, do you just butt the borla 3" pipe up to the factory 3in pipe and use a 3" sleeve style exhaust clamp like this correct? Or will the factory exhaust slide into the borla pipe? Just wanting to get everything together before I start cutting.
https://vibrantperformance.com/catal...8791706f474233
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap Last edited by ICTsccaCamaro; 11-14-2019 at 08:55 AM. |
11-13-2019, 08:52 PM | #2 |
factory piping isn't 3"...I used 2 3/4" band clamps for my Borla 60606.
11-13-2019, 08:55 PM | #3 |
11-13-2019, 09:37 PM | #4 |
Drives: all sold, getting another soon.. Join Date: May 2019
Yeah, 2.75" for ZL1 or SS. You cut the pipe as indicated, and the Borla slides over cut pipe, and tightened with included clamps. To go back to stock, buy the sleeve connector as pictured above, so the cut pieces can go back together edge to edge.
Larry
11-17-2019, 09:42 PM | #5 |
ITCRNRS
The 2 3/4" band clamps fit over the 3" borla pipes without to much of a fight?
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
