Old 10-14-2019, 01:25 PM   #1
David Klimis
Drives: ZL1 Camaro
315/3019 on all 4 side
Z-1LE has 325/3019 (12" rim) the rear and 305/3019 (11"rim) in the front. I was thinking about put a 315/3019 on all 4 sides? At least then I could have them removed, rotate and reinstalled them, per track weekend. I could also keep one spare around for both. And it's a great price! What's everybody else's thoughts? Good idea or bad?
David Klimis is offline   Reply With Quote
Old 10-14-2019, 05:28 PM   #2
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
I have ran all of these different tire sets on mine with no issues
305/30R19 front
325/30R19 rear
285/35R19 front
285/35R19 rear
305/30R19 front
305/30R19 rear
325/30R19 front
325/30R19 rear
305/30R19 front
355/30R19 rear
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 10-14-2019, 06:12 PM   #3
minn19
minn19's Avatar
Drives: 22 ZL1, 20 Taco, 20 Cayenne S
I'm going with 285/35/19 and 325/19/30 Pilot Sport A/S on Apex ARC-8 19X10 and 19X12. I should get it all together this weekend and am hoping it doesn't look/feel to funky for a fall/winter/early spring set.
minn19 is offline   Reply With Quote
Old 10-14-2019, 06:19 PM   #4
Markoz28
Drives: 18 ZL1 nightfall grey A10
When you do, start a thread and post pics.
Markoz28 is offline   Reply With Quote
Old 10-14-2019, 07:50 PM   #5
nighttowl
Sarcasm loading --------
nighttowl's Avatar
305/30R19 front
325/30R19 rear
285/35R19 front
285/35R19 rear
305/30R19 front
305/30R19 rear
325/30R19 front
325/30R19 rear
305/30R19 front
355/30R19 rear
Which tire combo yielded the best lap times?
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 10-14-2019, 07:53 PM   #6
minn19
minn19's Avatar
Will do.
Old 10-14-2019, 09:26 PM   #7
GT-ER
Drives: 2018 Camaro ZL1
305/30R19 front
325/30R19 rear
285/35R19 front
285/35R19 rear
305/30R19 front
305/30R19 rear
325/30R19 front
325/30R19 rear
305/30R19 front
355/30R19 rear
Yikes! On what wheel size did you run the 355?
GT-ER is offline   Reply With Quote
Old 10-14-2019, 11:18 PM   #8
ICTsccaCamaro
ITCRNRS
The stock 19x12, Kumho recommends a 12-13in wheel for the 355. They are a little pokey but just barely clear with the rear camber set a -2.3° in the rear with the camber curve under compression.
(Sorry for the sideways pictures)
Old 10-14-2019, 11:20 PM   #9
ICTsccaCamaro
ITCRNRS
The car has never felt better and more gripped up now with the 305 and 355 set up, I am running a Bridgestone RE71r in the front and a kumho ACR in the rear.
