Old 10-06-2019, 08:30 AM   #1
psipops
psipops's Avatar
Drives: 2016 2SS
TRAILER LOADING
Has anyone come up with a kit or a way to get ahold of the new Camaro`s to winch them into a trailer and then tie them down? The cars are so low and particularly the front it is hard to hook them up.The tow bolt in the grill isn`t all that good because of the offset from the center. Any ideas or help?
psipops is offline   Reply With Quote
Old 10-06-2019, 10:15 AM   #2
c4racer
Drives: 2016 SS Convertible
I've always driven a car on a trailer unless it wasn't running. There are risks both ways but I worry about using a winch, especially with a modern car.
c4racer is offline   Reply With Quote
Old 10-07-2019, 06:55 AM   #3
psipops
psipops's Avatar
Drives: 2016 2SS
My biggest concern is if there is maybe a bolt on kit to tie the car down once it is in the trailer. That could also serve to winch it in. I think.
Old 10-07-2019, 08:11 AM   #4
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
I Have e-track in the floor and bought straps that go over the tires. They click into e-track in front of and behind each tire then the strap stays tight to the floor and comes out from under the car and connects to a third point where you ratchet it tight. Only part of the car that is touched is the od of the tires. If you don't have e-track in you trailer you can add it for under 500 bucks including the 4 quality straps i bought.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 10-07-2019, 09:11 AM   #5
UrbanKnight
Drives: Fastish
I winch the car into my enclosed trailer using the zl1 add ons tow hook... yes its a bit off center, and it loads up the winch on one side, but no issues..
Unfortunately, unless you have etrack int he trailer, through the wheels has been the only way I have hooked up the car to tie it down.
UrbanKnight is offline   Reply With Quote
Old 10-08-2019, 04:31 PM   #6
Dave-ROR
Drives: A few
This except I use the stock tow hook. It's not off center enough to cause an issue unless you winch it right up to the winch itself. I stop probably 8' from the winch and has it minimal side loading, maybe 10 degrees or something.
I tie down by the wheels as well. Crossed in the back and straight in the front.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
Old 10-08-2019, 04:48 PM   #7
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Just offset your winch on the trailer and use the tow hook. I bought the Summit blue straps and tie mine down over the front arms and the rear over the main arm for the coil springs. Use a axles strap on the front and the rear. I've been towing my Camaro like this for over 3 years. Works awesome.
Old 10-08-2019, 04:56 PM   #8
laynlo15
laynlo15's Avatar
I replace my straps every couple years also. They take a beaten and frayed a little and for 100 bucks its not worth the chance to have one fail. I tow a lot. I don't have pictures of the front. I had a 1 year old 24 ft Titan enclosed trailer but had some issues with the siding and went back to an open 20 ft Sundowner, this MOFO is the best trailer I've ever owned. No steel trailers for me ever.
Old 10-08-2019, 04:56 PM   #9
Dave-ROR
Drives: A few
That only works if you have one car to tow. First world problems I guess but I have 2 endurance cars and 3 HPDE cars that I could be towing.. but yeah I guess you could do that if you only had the one and never see a reason to switch cars in the future
-Dave
Old 10-08-2019, 05:46 PM   #10
Chevy1American
Drives: 2SS
https://zl1addons.com/collections/ca...maro-tie-downs
Chevy1American is offline   Reply With Quote
Old 10-08-2019, 06:02 PM   #11
Originally Posted by Chevy1American View Post
These work great... unfortunately the front doesn't work anymore for me since I got new MAC tiedowns with a large hook on the end. I go through the wheels on the front and use ZL1 Addons in the rear.
Old 10-09-2019, 06:55 AM   #12
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
OMG! You guys are towing with a 1500 series truck... Oh my!
There are people on the forum that will tell you this is bad...
:-) Just yankin ya...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 10-09-2019, 07:33 AM   #13
laynlo15
laynlo15's Avatar
Yep, I towed my enclosed with my 1500 and mine has a 6.2 with air bags on the rear plus its lowered 2-4 so tows awesome and I do use a sway bar in case its windy. No big deal tow 78 to 80 mph all the time and the trailer has 4 wheel brakes so I never worry about not being able to bring her down if needed. How you load it is the most important thing as to how the trailer acts behind you. Got that down perfectly and I've towing for 51 years so I'm good to go. I do have a Magnuson SC to install on mine at some point but just haven't gotten around to it yet.
Old 10-11-2019, 08:02 AM   #14
psipops
psipops's Avatar
Drives: 2016 2SS
[QUOTE=Chevy1American;10636276][url]https://zl1addons.com/collections/camaro-accessories/products/camaro-tie-down
I have the ZL1 Addons tie down links and the jack pad coming. I will figure out how to use them with my enclosed trailer. Thanks for all the response. I think this post turned out good.
