Old 10-06-2019, 03:57 AM   #1
Firehead640
DEVLMAN
Drives: White 2018 ZL1
AutoX track settings
Out of curiosity, what are you guys using for your track settings? I'll be taking the ZL1 out for its first track related event next weekend, and I'd like to hear your opinions on which track settings I should play with.
I'll be rocking my Continental Extreme Contacts in stock sizing, if it matters. I expect to spin a quite a bit, but anything I can do to maximize my cars capability on the course would be fantastic.
Firehead640 is offline   Reply With Quote
Old 10-06-2019, 06:25 PM   #2
Og Neon
Lover of Speed
Drives: 2018 ZLE
I usually do my first run in Track Mode Race Setting, and then after that the rest of the runs are done with everything off (traction button held down for 7 seconds). You have to be on it to stay ahead of the car though. If you are new to autox using race or sport 2 can help you out.
Are you running at Marana or Arizona Motorsports Park (AMP)? I just moved from the Phoenix region so I am familiar with where you will be. If at AMP your car will not pass the sound test. You can make some turn downs though and it will then pass.
Killer Whale Racing
2021 One Lap of America Track Videos
2019 One Lap of America Track Videos
2017 One Lap of America Track Videos
2022 Ram TRX
2018 Camaro ZL1 1LE
2020 Range Rover Sport SVR (Sold)
2014 Grand Cherokee SRT (Sold)
2014 Camaro Z/28 (Sold)
Og Neon is offline   Reply With Quote
Old 10-06-2019, 07:29 PM   #3
sv340
sv340's Avatar
Drives: 2015 ZL1
I suspect if your competitive at all you will want to burn your tires after your second run. Pretty hard to be competitive with those tires even in a stock class, and if your in CAM-C your pride will take a real beating. I would run with nannies off as well, but given your handicapped with your tires, you may want to leave them on. You have at least 650 hp but you wont be able to use half of that. I say that, but if its raining or cold as hell you might look like a hero if you can keep your foot out of it.
sv340 is offline   Reply With Quote
Old 10-07-2019, 12:10 PM   #4
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Track drive mode with all nannies off for autocross and track drive mode with PTM in race mode for trackdays
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
