09-07-2019, 12:52 PM | #15 | |
Drives: SS 6 speed of course Join Date: Jan 2016
All four "hoses" on the Vette manifold are much bigger. The two things the Camaro has going for it are: 1) It is a try-y design which helps midrange torque 2) most of its tubes are longer, which helps mid-range. The bads, it has many twists and turns and the merges are not as smooth as the Vettes; which is basically a big oval collector with completely linear merges flows (ideal). I measured the internal primary tube it is a rounded corner square cross section 1.2" x 1.4" about 1.7 sq inches lets just call this a 1.5" ID or 1.6 OD tube ( 1 and 5/8 header). Really not too bad. The ported Vette was 2"ID or 85% more cross-sectional area. Have no idea how big the unported entry is nor the rectangle cross-section of the port would be.
12-13-2019, 11:23 PM | #16 | |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
But anyway the fact that GM redesigned so many parts specific to the ZO6 (and I am assuming the ZR1) proves to me there is room for improvement. |
12-15-2019, 09:30 AM | #17 | |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Baby Blue
01-18-2020, 04:06 PM | #18 |
Here is a large cam similar (less overlap) to a GM hotcam, 90% stock exhaust, I have a CA front cat delete on the driver's side to test part throttle E85.... sorry
https://youtu.be/AfoP1LPXdUo
