01-21-2023, 06:08 PM | #15 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Duramacr1 has a converter and a unlocked trans making the the car as quick with a lot less horsepower. BTW, 3400 lbs with driver is pretty light. Just My two cents Craig.
01-21-2023, 09:10 PM | #16 |
The converter and trans unlock are probably worth at least 4 tenths. Yest the 3400 with a 250 lb driver is very light since the car weight 3640 bone stock, that's what mine weighed on our local scales.
01-22-2023, 10:44 AM | #17 |
The car would have to be 3250 lbs, kind of hard to find a driver that weighs less than 150lbs. Not easy to remove 400lbs from a 3640 lb LT1
01-22-2023, 10:56 AM | #18 |
2Spdsy
Drives: 2021 Camaro LT1 A10 Join Date: Mar 2016
LT4camaro, my jockey is 125lbs with the helmet on .. The car weighs 3125 with a 1/4 tank and I’m 275 with helmet . We both run the car but when it comes time for a grudge I take the keys cuz I cut pretty good lights .
01-22-2023, 11:10 AM | #19 | |
01-22-2023, 11:59 AM | #20 |
2Spdsy
LT4camaro. I have no problem posting my weight reduction here. I always tell people I’m an open book. I don’t hide anything . I like helping others and seeing other people go fast as well. I’m not selfish and don’t really grudge race on the street since my class A is my lively hood . My dragpak and aerospace brakes all around is worth 200 lbs .
. My car was 3600 with a 1/4 tank when I bought it. All stock wheels etc. Weighed it the 3 days after I bought it . Here is the list 1. Aerospace front and rear. 80lbs 2. RC Comp torque wheels 15” conversión all around . 120lbs 3. Antigravity battery 30lbs 4. Headers , no cats , pypes mufflers 50lbs 5 . Front cowl with wipers . Unbolted to clear high ram 25lbs 6 . Front & Rear bumper supports. 35lbs 7. Passenger & rear seats 65lbs 8 . Washer reservoir with water 15lbs 9. Carbon fiber intake manifold and ram air. 10lbs 10. DSX billet valve covers. 8lbs 11. Cut stock hood 7lbs This is all I can think of right now . Car still has stock front seat, all carpet , AC, Heater , Etc. I tried a Kirky seat and couldn’t stand it so took it off in 2 days . Also tried axle dumps and took the off right away . I run the stock midpipe To 3 inch Pypes turbo mufflers out the stock location but that only saved 20lbs. It is the quietest 6th Gen at the track . Car made 532/470 on the dynocom . Last edited by Duramacr1; 01-22-2023 at 12:01 PM. Reason: Wrong number |
01-22-2023, 12:04 PM | #21 |
2Spdsy
01-22-2023, 12:51 PM | #22 |
The front seat is 58 lbs and the rear are 28 lbs for the seat bottom and seat back. So, that's 86 lbs
01-22-2023, 01:36 PM | #23 | |
01-22-2023, 02:41 PM | #24 | |
01-22-2023, 04:28 PM | #25 |
2Spdsy
Guys I knew I was missing something . Obviously the belly pan and front swaybar. Another 25 or so. I actually took that off after 3 days of having the car .
LT4 , the cowl is a piece of metal that unbolts off the car. It don’t drive the car in the rain so I’m not worried about wipers . Everything together is 25lbs. And everything can go back on in an hour. I decide to do that ínstead of cutting it to fit the high ram. |
01-22-2023, 04:32 PM | #26 |
2Spdsy
01-22-2023, 05:35 PM | #27 | |
01-22-2023, 05:46 PM | #28 |
Drives: 98 Camaro Join Date: Apr 2022
I saw that intake manifold on FB. Sounds promising and much lighter than a hi ram. Crazy the valve covers saved 8lbs. Never had them off but they must be a good amount heavier than Ls valve covers. You should make a whole new post with your weight reduction/mods etc. good info
