01-07-2023, 09:08 AM | #1 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Extra ground wire
Folks, I ordered the extra ground wire from Lethal Garage, but I am struggling to figure out where to mount it on my LT4 engine.
In the pics provided with the wire, it is clearly an SS LT1 and the mount they use on the engine is covered by the supercharger belt. Can anyone post a pic of where they mounted this on their ZL1's LT4 engine? To me, the only place I see that might work is a bolt from one of the pulleys on the main belt.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
01-07-2023, 10:12 AM | #2 |
For the sake of you two who were quick to jump on SteveV: https://www.camaro6.com/forums/showthread.php?t=586153
01-07-2023, 01:25 PM | #3 |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
An extra ground loop is 1000% helpful on any vehicle running an all aluminum engine setup. For whatever reason AL is not as conductive as their cast iron counterparts. I had to do the same to my truck and all of its weird issues went away as soon as I did.
As far as your ground strap goes tie it from the ground post at the body and run it over to the bolt that holds onto the factory catch can. If I remember correctly that's how I did mine and to confirm it was grounded for sure to the block I used a power probe to confirm it was providing a clean ground prior to running the strap. In order to complete the ground loop properly you will need a ground strap in the trunk as well. I ran one from the battery to the floor where one of the modules mounts to. You can't run a ground up front or behind without strengthening the other side as well otherwise it won't be as effective. I have noticed improved cranking ever since i did mine on my car. I hope this helps!
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
01-07-2023, 01:54 PM | #4 |
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
Disproven many times. Hopefully saying snake oil is enough to dissuade others. Modern cars are all properly grounded and there are ZERO PERFORMANCE GAINS to be had from adding some BS extra ground.
This is the kind of BS you see on the Honda V-tech forums. P.S. I’ll race anyone stock for stock heads up and I’ll let you add a grounding wire for the imaginary 5K rwhp. $1,000 and I pick the track.
1997 Z28 Anniversary Edition SOLD
2004 GTO ORDER CANCELLED 2004 CTS-V SOLD 2005 CTS-V SOLD 2006 300C SRT-8 SOLD 2006 300C SRT-8 SOLD 2010 CTS-V SOLD 2012 CTS-V coupe SOLD 2013 ZL1 vert SOLD 2016 Callaway Z06 SOLD 2019 Z06 SOLD "I lived my life by one motto.......mottos are for losers" cvp33 |
01-07-2023, 02:34 PM | #5 | |
Drives: Chevrolet Camaro LT1 Join Date: Sep 2022
GM and many other auto manufacturers try to provide the absolute lowest cost solutions to everything in a car. Sometimes those "lowest bid" solutions work well, but sometimes they do not. Jim G |
01-07-2023, 02:49 PM | #6 | |
Next time you might want to read the linked thread that discusses the problem and the experience of those with and without this ground strap.
01-07-2023, 02:51 PM | #7 | ||
Cvp it's not snake oil if the goal and outcome achieve their desired effects. At no point is anyone here adding them for "power gains." They are adding them for better electrical conductivity all around, eliminating the possibility of potential electrical gremlins and startability issues. If you or anyone else believes that folks are adding grounds to get more HP out of it then you or they probably belong on the Honda forums yourselves.
737 HP/ 779 TQ |
01-07-2023, 03:24 PM | #8 | |
Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
here ya' go amigo
good mod for heat soak problems |
01-07-2023, 03:58 PM | #9 |
America FVCK Yeah!
Never had a ground issue on any of my cars or builds. Never had a phantom C/E light, a hard start, or any of the other imaginary gremlins. But if a $5 ground wire helps you sleep better at night…….I suggest adding 3 or 4 to get maximum benefit. LOL ~~~~~~~e~ + oil
01-07-2023, 04:12 PM | #10 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I’ve been having a grounding/electrical gremlin on mine. I might have to try this. Thanks for the tip.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
01-07-2023, 04:56 PM | #11 | |
I know how important a good chassis ground is for proper automotive electronic performance. The 2016 SS model has an inadequate/defective factory ground that will not overcome starter heat soak. Rather than chase down the factory ground problem I just added a robust and solid engine to body ground. It’s a fast, cheap and easy fix. I can not speak about the models since 2016 but for all I know GM did a better job with chassis grounds and/or eliminating starter heat soak after 2016. So, you may not have any concerns about your car which is a good thing. For everyone else if you have concerns or problems with electrical gremlins - adding a ground cable is easy and cheap. You can not have such a thing as too good of a grounded circuit flow. And no sorry - there will be no HP gains but I do now have a car that will start no matter how much starter heat soak I get. Read my thread - a huge number of people duplicated my results.
01-07-2023, 05:02 PM | #12 |
cvp33: A good, confident man admits when he might have given an opinion before being shown all the facts.
Jim G |
01-07-2023, 05:05 PM | #13 | |
737 HP/ 779 TQ |
01-07-2023, 06:18 PM | #14 |
