12-22-2022, 02:55 PM | #1 |
Drives: 2019 Camaro 2SS Vert Join Date: Apr 2020
Momo Wheels
Saw this thread in the ZL1 section and thought I would ask the question here in the wheels section if a square 19x11 would work for '19 SS. Kinda like the look of these wheels for $99/ea
https://www.camaro6.com/forums/showthread.php?t=612236 |
12-22-2022, 03:35 PM | #2 |
Who Needs to KNOW?
Due to only offset available at price being 35, you will need spacer by my math.
I'll be able to confirm in few days - my set has shipped!
ing for grip.
12-22-2022, 03:41 PM | #3 |
Definitely would need a 10mm spacer in the front and with 11” wheel you might get “Super Poke”.
This was to OP!
12-28-2022, 12:53 PM | #4 |
Thanks Trochoidal ... no one likes "Super Poke" :P
12-28-2022, 02:53 PM | #5 |
Who Needs to KNOW?
Quite the opposite - you'll need spacer up front to clear the strut.
Prob around 20mm spacer to get somewhere near flush w fender. They look good though. My MRR 716 are showing some age - so many be i change over, but will need longer studs and aforementioned spacers. If weather stays warm, maybe I check in the next few days.
ing for grip.
12-29-2022, 05:40 PM | #6 | |
I’m on a 10” wide wheel with +23 and I’m flush now. I’d expect the extra 12.7mm per side to have that wheel pushed out beyond the fender.
12-29-2022, 05:47 PM | #7 |
Who Needs to KNOW?
If you send me SS stock fitment i can rerun the math in the spreadsheet.
ing for grip.
12-29-2022, 06:28 PM | #8 | |
SS tires (front) 245/40R20 - 27.7x9.7R20 (rear) 275/35R20 - 27.6x10.8R20 SS OEM wheels 20x8.5 25mm offset 20x9.5 39mm offset
12-29-2022, 06:47 PM | #9 |
Who Needs to KNOW?
Certainly looks like without WIDE fenders, front WILL will stick out a bunch.
ing for grip.
12-29-2022, 07:34 PM | #10 |
Nice spreadsheet you have VTOR. Did you make this or grab it from the web?
12-29-2022, 07:54 PM | #11 |
Who Needs to KNOW?
Made it - helped me figure out what fit and what didn't.
See attached - has 3 tabs, wheels, tires and last addition.. studs
ing for grip.
